67 Convertible Top Frame Paint Code and Type #2798569
07/19/20 12:08 PM
07/19/20 12:08 PM
Sin City
calif67rt Offline OP
Sin City
I am restoring a 67 Coronet convertible and want to paint the convertible top frame before installing the top fabric. Either in this forum or in the Q&A forum I saw something about this but I can't find it again. Waht is the correct paint code for the black frame and what type of paint should be used? I have CRS but I think it said you have to use a special paint type.
Thanks for the help.
Bill
Re: 67 Convertible Top Frame Paint Code and Type [Re: calif67rt] #2798873
07/20/20 10:41 AM
07/20/20 10:41 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Restoring my 68 Dart frame is on my list for this year. SEM Trim Black seems to be a great color match for what I've seen but my frame has been exposed to the elements quite a bit. I'd be interested in hearing what others have used.
Re: 67 Convertible Top Frame Paint Code and Type [Re: burdar] #2798947
07/20/20 02:09 PM
07/20/20 02:09 PM
Sin City
Sin City
A friend of mine repainted his top frame using rattle-can paint. A while after he put the top on the paint started to bleed through. I don't want that to happen as I am using a white top. Hopefully someone can help.
Re: 67 Convertible Top Frame Paint Code and Type [Re: calif67rt] #2798949
07/20/20 02:14 PM
07/20/20 02:14 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
SEM sells their paint in 1 gallon and 1 quart sizes. They don't just sell it in spray cans.
Re: 67 Convertible Top Frame Paint Code and Type [Re: burdar] #2799064
07/20/20 06:56 PM
07/20/20 06:56 PM
Southeast PA
5wndwcpe Offline
5wndwcpe  Offline
Southeast PA
I use SPI black epoxy.
1968 GTX hardtop
1968 Sport Satellite Convertible 383/4spd
1933 Plymouth coupe
2002 Ram 2500 oil burner 4x4
2015 Grand Cherokee
2013 Challenger
1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
Re: 67 Convertible Top Frame Paint Code and Type [Re: 5wndwcpe] #2799432
07/21/20 03:23 PM
07/21/20 03:23 PM
NW Arkansas
challengersteve Offline
NW Arkansas
I just restored a convertible top frame for a customer and I blasted, epoxy primed and painted in single stage urethane with 40% flattening agent mixed in. Looks spot on and will not fade or allow moisture underneath.
Re: 67 Convertible Top Frame Paint Code and Type [Re: challengersteve] #2800986
07/25/20 01:01 PM
07/25/20 01:01 PM
Sin City
Sin City
Thanks for the info folks. It is greatly appreciated.
Re: 67 Convertible Top Frame Paint Code and Type [Re: calif67rt] #2801360
07/26/20 02:17 PM
07/26/20 02:17 PM
St Louis, MO 63026
convx4 Offline
convx4  Offline
St Louis, MO 63026
Get your new top before you restore the frame. When I replaced the top on my 65 coronet I had to paint the frame. Originally the outside and inside of the top was white, with the frame white also. My new top had the outside white and the inside black. The original white frame would have stuck out badly if left original white. At the time I could not find a white white top, don't know if they are offered today.
