After letting it languish for a
long time, I want to get the Barracuda running. I got it to this stage, about 85% done, more than ten years ago when first one thing and then another kept pushing it down the priority list. It's been in the garage since '97 as I did the body and paint, installed an 8-3/4 with 3.23s, big bolt pattern conversion, upgraded drums on the rear and discs in front. I rebuilt an '86 318 with a mildly-reground roller cam and -302 heads using 340 manifolds. Performer intake and carb. Should be a nice driver combo if I can get it going.
I need a radiator, and I'm having some trouble picking one out. It needs to fit a '69 Barracuda, but with '86 hose locations (upper driver inlet, lower passenger outlet). I like the looks of ECP radiators, but they're showing most of their Mopar rads as out of stock; not a good sign. US Radiators are north of $600. Too much if not absolutely necessary.
This one from Mancini looks like a good candidate. They spec it for a '70-72 Duster/Dart but it should bolt in, shouldn't it? Suggestions appreciated.
