ECU / WHERE TO GET THE GOOD ONES #2797210
07/15/20 10:16 PM
07/15/20 10:16 PM
S.E.Ohio
Magnumguy Offline OP
S.E.Ohio
Where can you buy good units? Seems like ones that have "Chrysler" on them have about a 50% failure rate.
Aftermarket or ???
thanks
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: ICU / WHERE TO GET THE GOOD ONES [Re: Magnumguy] #2797247
07/16/20 04:20 AM
07/16/20 04:20 AM
Abilene, Texas
fastmark Online content
fastmark  Online Content
Abilene, Texas
Do you mean ECU? If so read my post on the bouncing timing mark in this section.
Re: ICU / WHERE TO GET THE GOOD ONES [Re: fastmark] #2797257
07/16/20 06:40 AM
07/16/20 06:40 AM
S.E.Ohio
S.E.Ohio
Yes, I did. and I will
Re: ICU / WHERE TO GET THE GOOD ONES [Re: Magnumguy] #2797562
07/16/20 07:42 PM
07/16/20 07:42 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Mopar Performance P4120505 Orange
Mopar Performance P4120534 Chrome
Have not been made in years
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: ICU / WHERE TO GET THE GOOD ONES [Re: bee1971] #2797735
07/17/20 08:56 AM
07/17/20 08:56 AM
Charlotte, NC
Kowal Offline
Kowal  Offline
Charlotte, NC
I have been using the blue one out of JEGS. This is also the one that Ehrenberg pushes on his e-bay store. I like it. Have used it on three cars now, I think it is better than the orange box at start and idle. Have had no problems with it.
I mounted one behind the front passenger headlight on my Charger, worried about heat. But the other two have been on the firewall and have done fine.
You do need a ballast with it. I also run an Accel 8140 coil (repainted black) which seems like a good match for it.
Note...this is a street driven car
'69 Hemi Charger 500, ‘70 U code Challenger R/T
(These and a bunch others at www.dkowal426.com)
P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
Re: ICU / WHERE TO GET THE GOOD ONES [Re: Kowal] #2797858
07/17/20 12:28 PM
07/17/20 12:28 PM
Stoney Creek, Ontario, Canada
76Beeper Offline
76Beeper  Offline
What about trying the Rev-n-nator orange box? work
Re: ICU / WHERE TO GET THE GOOD ONES [Re: bee1971] #2797868
07/17/20 12:40 PM
07/17/20 12:40 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
A few months ago I was looking for one, and I just scouted epay and got a few aftermarket brand NOS ones made 30-40 years ago I got a niehoff, I think an etron and a blue streak
All brand new but old enough to be American made, bought from different sellers.
So far I have used 2, one for a lean burn delete on an 85 D 150 and the 2nd one to rescue my son's 80 D150 that wouldn't pull itself to the parking space when he coasted into a parking lot and it wouldn't pull itself into the parking spot just in front of where he has stopped, as the potting had all melted out of the original 40 yo ECU.
#3 is going into my 78 Fury for it's lean burn ectomy. I do look when I am in the boneyards for them, would trust a used one that works when I plug it in over a new, current unit from today's parts stores that was made who knows where. At least as a ready spare
Re: ICU / WHERE TO GET THE GOOD ONES [Re: 76Beeper] #2798057
07/17/20 08:28 PM
07/17/20 08:28 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Out Of Stock - Has been for months , Maybe a year ?
Standard LX101 is about as good as it gets from any parts store
Siberian Huskies
Re: ICU / WHERE TO GET THE GOOD ONES [Re: bee1971] #2798080
07/17/20 09:24 PM
07/17/20 09:24 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Problem is the original power transistor and quality substitutes went out of production and the redesign isn't as robust.
Re: ICU / WHERE TO GET THE GOOD ONES [Re: Sniper] #2798085
07/17/20 09:48 PM
07/17/20 09:48 PM
BDW Offline
BDW  Offline
What year / timeframe did that happen?
Re: ICU / WHERE TO GET THE GOOD ONES [Re: BDW] #2798089
07/17/20 09:57 PM
07/17/20 09:57 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Well, the ST version went out of production in 2013, not sure when the Motorola version did. You can get offshore versions of the Motorola one, but the kwailty is real poor and even then the genuine Motorola one was not as capable as the ST one, 10A capacity versus 15A.
Re: ICU / WHERE TO GET THE GOOD ONES [Re: Sniper] #2798297
07/18/20 01:02 PM
07/18/20 01:02 PM
Badham Co.
Y
Y3 70 BEE Offline
Y3 70 BEE  Offline
Y
Badham Co.
Cut open a current parts store ECU and there is just a modern style chip in it. Nothing like the originals and the transistor is just there for show. I put a 4 pin GM module in a old Chrysler ECU body and run that.
Re: ICU / WHERE TO GET THE GOOD ONES [Re: Y3 70 BEE] #2801463
07/26/20 06:37 PM
07/26/20 06:37 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Siberian Huskies
Re: ECU / WHERE TO GET THE GOOD ONES [Re: Magnumguy] #2801589
07/27/20 05:15 AM
07/27/20 05:15 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
Gut an old ECU and put an 4-pin GM HEI-module in it.
Ensure a good coolingcontact againt the housing and connect the pins to the original connector on the inside, no-one will know the difference.
Howto-manuals can be found online with a simple search.
Re: ECU / WHERE TO GET THE GOOD ONES [Re: Magnumguy] #2801611
07/27/20 08:30 AM
07/27/20 08:30 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
has been told the Standard LX101 gets a good rate of use without failures
on the Hi-Rev 7500 box I have got splitted experiences. Is my spare one. I used for a week before get the Rev-N-Nator, but a friend of mine got it and last long 3 or 4 months.
Re: ICU / WHERE TO GET THE GOOD ONES [Re: 76Beeper] #2802968
07/30/20 04:13 PM
07/30/20 04:13 PM
Planet Earth
RoadRunnerLuva Offline
Planet Earth
If you can find one of these, get one! Works great in my car...no problems at all, and has adjustable rpm rev limit as well. I use the MSD Blaster 2 coil and 4 pin ballast.
Plymouth Makes It!
Re: ICU / WHERE TO GET THE GOOD ONES [Re: RoadRunnerLuva] #2803697
08/01/20 12:55 PM
08/01/20 12:55 PM
Is this one (hrr688) on eBay the rev-n-nator?
Re: ICU / WHERE TO GET THE GOOD ONES [Re: RapidRobert] #2803703
08/01/20 01:03 PM
08/01/20 01:03 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Rev-n-ator says rev-n-ator on it.
http://rev-n-nator.com/
Re: ICU / WHERE TO GET THE GOOD ONES [Re: Sniper] #2803707
08/01/20 01:12 PM
08/01/20 01:12 PM
Thanks bro. if the revnnator is going to be out of stock for quite awhile I'm wondering if this one would be a suitable substitute?
Re: ICU / WHERE TO GET THE GOOD ONES [Re: RapidRobert] #2803709
08/01/20 01:14 PM
08/01/20 01:14 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
No idea, never used either. I still run points.
