ECU / WHERE TO GET THE GOOD ONES
#2797210
07/15/20 10:16 PM
07/15/20 10:16 PM
Posts: 10,630 S.E.Ohio
Magnumguy
S.E.Ohio
Where can you buy good units? Seems like ones that have "Chrysler" on them have about a 50% failure rate.
Aftermarket or ???
thanks
Re: ICU / WHERE TO GET THE GOOD ONES
[Re: Magnumguy]
#2797562
07/16/20 07:42 PM
07/16/20 07:42 PM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
Mopar Performance P4120505 Orange
Mopar Performance P4120534 Chrome
Have not been made in years
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: bee1971]
#2797735
07/17/20 08:56 AM
07/17/20 08:56 AM
Posts: 531 Charlotte, NC
Kowal
Charlotte, NC
I have been using the blue one out of JEGS. This is also the one that Ehrenberg pushes on his e-bay store. I like it. Have used it on three cars now, I think it is better than the orange box at start and idle. Have had no problems with it.
I mounted one behind the front passenger headlight on my Charger, worried about heat. But the other two have been on the firewall and have done fine.
You do need a ballast with it. I also run an Accel 8140 coil (repainted black) which seems like a good match for it.
Note...this is a street driven car
'69 Hemi Charger 500, ‘70 U code Challenger R/T (These and a bunch others at www.dkowal426.com) P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
[Re: 76Beeper]
#2798057
07/17/20 08:28 PM
07/17/20 08:28 PM
bee1971
Sobieski Wi
What about trying the Rev-n-nator orange box? Out Of Stock - Has been for months , Maybe a year ? Standard LX101 is about as good as it gets from any parts store
[Re: Sniper]
#2798085
07/17/20 09:48 PM
07/17/20 09:48 PM
Posts: 4,681 Florida
BDW
Problem is the original power transistor and quality substitutes went out of production and the redesign isn't as robust.
What year / timeframe did that happen?
Re: ECU / WHERE TO GET THE GOOD ONES
[Re: Magnumguy]
#2801611
07/27/20 08:30 AM
07/27/20 08:30 AM
Posts: 6,089 Valencia, España
NachoRT74
Valencia, España
has been told the Standard LX101 gets a good rate of use without failures
on the Hi-Rev 7500 box I have got splitted experiences. Is my spare one. I used for a week before get the Rev-N-Nator, but a friend of mine got it and last long 3 or 4 months.
[Re: 76Beeper]
#2802968
07/30/20 04:13 PM
07/30/20 04:13 PM
Posts: 5,283 Land 'O Lakes
RoadRunnerLuva
Land 'O Lakes
What about trying the Rev-n-nator orange box? If you can find one of these, get one! Works great in my car...no problems at all, and has adjustable rpm rev limit as well. I use the MSD Blaster 2 coil and 4 pin ballast.
Plymouth Makes It!
