Re: MODIFY SB TIMING COVER FOR -AN [Re: MR_P_BODY] #2798357
07/18/20 03:25 PM
07/18/20 03:25 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
The Durango pump puts out 25 gpm.
Re: MODIFY SB TIMING COVER FOR -AN [Re: slantzilla] #2798359
07/18/20 03:25 PM
07/18/20 03:25 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Originally Posted by slantzilla
The Durango rear heater pump Monte reccomended used to be about $75 from Dorman.
Do you have a P/N or info on this pump.. might have to look into this one being much cheaper
to do the same thing(if its pumps enough)
wave
Re: MODIFY SB TIMING COVER FOR -AN [Re: A/MP] #2798361
07/18/20 03:28 PM
07/18/20 03:28 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats a bit low.. I guess I look at the other.. thanks
wave
Re: MODIFY SB TIMING COVER FOR -AN [Re: MR_P_BODY] #2798398
07/18/20 05:31 PM
07/18/20 05:31 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
Just an FYI on that pump, its a helper pumper for distributing hot water/heat for the back of the vehicle. I believe that there are issues using this pump as racers intend. Its not self priming. About $75.00 for off brand replacement.
