727 trans bolt location #2794761
07/09/20 03:02 PM
07/09/20 03:02 PM
Virginia
V
vadartlover Offline OP
V
Virginia
so.....my utter brilliance is on display once again. I had an empty transmission that has been sitting for years and decided to replace the filter then fill er up. Everything thing went really smooth, except after removing several bolts, notice there are two different lengths, o [censored]. No biggie, just put them back where they will bolt in, done. Then I filled her up and closed up and was done for the day. How satisfying it was!!!
Then to my utter dismay, I returned to the garage the next day to the smell of trans fluid and a puddle on the floor. So, either I placed the bolts in the wrong holes or someone broke in and loosened the bolts. So now I need to find a chart or map that shows which bolts go where. Once I see that, I have to figure which bolts are which and rearrange them without losing anymore fluid, stuff is expensive!!
Anyone have a link to said chart or map?
That said, thinking about opening a transmission shop on the side!!!!
Re: 727 trans bolt location [Re: vadartlover] #2794777
07/09/20 03:19 PM
07/09/20 03:19 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I think the 2 longer bolts go under the shifter area but not sure.
Re: 727 trans bolt location [Re: Clanton] #2794792
07/09/20 03:39 PM
07/09/20 03:39 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
If you look at the bolt holes you will see some go into the trans case and some go through the outside the long bolts can go to the outside holes.
Re: 727 trans bolt location [Re: vadartlover] #2794813
07/09/20 04:20 PM
07/09/20 04:20 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
If my memory serves, the factory layout used the same length bots all around. And they were sorta short.
Re: 727 trans bolt location [Re: buildanother] #2794817
07/09/20 04:30 PM
07/09/20 04:30 PM
A727Tflite Online content
A727Tflite  Online Content
Correct. All pan bolts are the same length.
Probably the case has a couple stripped threads and the previous person installed the long bolts there. You should have felt the bolts not going to torque if that is the case.
Re: 727 trans bolt location [Re: A727Tflite] #2794963
07/09/20 09:43 PM
07/09/20 09:43 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
The bolts may be the cause of your leak, but if the trans has sat empty for years, I think I would be looking at replacing the seals on the shift lever (there is 2 seals there, an inner one around the kick down lever and an outer one around the shaft body). I'm betting you will find trans fluid running from the shift seal(s) down to the pan gasket, the running along the pan gasket to the lowest point and then dripping off. The seal at the dipstick could do the same thing. The trans cooler lines leaking at the trans connection will also appear as a pan leak, and a defective park/neutral switch will do the same thing.
I chased what I thought was a pan gasket leak for years before I discovered these other leaks that will run down on the pan gasket and make it look like its leaking. Gene
Re: 727 trans bolt location [Re: poorboy] #2795140
07/10/20 01:16 PM
07/10/20 01:16 PM
moparx Offline
moparx  Offline
look at the rear servo pivot pin area at the rear of the case as well.
the o-ring on the pin could be bad.
beer
Re: 727 trans bolt location [Re: moparx] #2795148
07/10/20 01:29 PM
07/10/20 01:29 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
The young gEeZeR ^^^^^^^ ... might be right !
Just hit that area with some brake clean spray ... and check later
Re: 727 trans bolt location [Re: dOrk !] #2795155
07/10/20 01:49 PM
07/10/20 01:49 PM
moparx Offline
moparx  Offline
HaY DoC ! is you sayin' YoU is OlDeR than mE ??????? eek eek eek laugh2 whistling work devil stirthepot biggrin
beer
Re: 727 trans bolt location [Re: buildanother] #2795157
07/10/20 01:53 PM
07/10/20 01:53 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Yes, and the threads can be stripped from over-torqueing. Slightly longer bolts will sometimes catch the remaining threads in a stripped hole. Visually inspect the first threads in every hole, any missing is the location of the longer bolt(s).
Re: 727 trans bolt location [Re: moparx] #2795163
07/10/20 02:13 PM
07/10/20 02:13 PM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
beer
Now oleHam2.. no one here that I am aware of could claim that BADGE OF HONOR ! wave
Re: 727 trans bolt location [Re: dOrk !] #2795207
07/10/20 04:00 PM
07/10/20 04:00 PM
md
mopars4ever Offline
mopars4ever  Offline
md
For the holes that don`t go all the way thru, do yourself a favor and make sure any sealer or gunk is cleaned out of those bolt holes. The bolts can bottom out on the gunk and make you think the pan is tight and it may not be.
