Help on a roller lifter #2793604
07/06/20 07:23 PM
07/06/20 07:23 PM
New Smyrna Beach FL
scottb Offline OP
scottb  Offline OP
New Smyrna Beach FL
Can some one help me identify these small block mopar roller lifters there are no markings any where thanks
Re: Help on a roller lifter [Re: scottb] #2793646
07/06/20 08:26 PM
07/06/20 08:26 PM
MR_P_BODY Offline
MR_P_BODY  Offline
They look like they are for a 48* block.. I dont know that tie bar.. they have a large clearance
between the roller and lifter
wave
Re: Help on a roller lifter [Re: MR_P_BODY] #2793661
07/06/20 09:07 PM
07/06/20 09:07 PM
A727Tflite Offline
A727Tflite  Offline
Not sure how old those are but I have a set of Engles that look very similar to your’s.
Re: Help on a roller lifter [Re: A727Tflite] #2793665
07/06/20 09:21 PM
07/06/20 09:21 PM
New Smyrna Beach FL
scottb Offline OP
scottb  Offline OP
New Smyrna Beach FL
I have no idea either they were in a motor I bought stock 59 degree 340 block
Re: Help on a roller lifter [Re: scottb] #2793678
07/06/20 09:54 PM
07/06/20 09:54 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I never seen that type of tie bar in a 59*
wave
Re: Help on a roller lifter [Re: MR_P_BODY] #2793682
07/06/20 10:08 PM
07/06/20 10:08 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
If you are in Brett Millers Facebook page I’m betting he could ID them for you. The bar is on the inside like some of the Comp lifters.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Help on a roller lifter [Re: pittsburghracer] #2793873
07/07/20 12:07 PM
07/07/20 12:07 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Looks like the link bar is open/slotted on the end?
Seems like I used lifters with link bars like that a very long time ago....... like in the 80’s.
Maybe early Crowers?
Re: Help on a roller lifter [Re: scottb] #2794109
07/07/20 10:46 PM
07/07/20 10:46 PM
They don't look like any SB Mopar LA motor roller lifter I've seen confused shruggy
I haven't work on any SB Mopar produced and used after 1976 also shruggy
