Re: 4 Post Car Lift
[Re: gygeneral]
#2801336
07/26/20 01:27 PM
07/26/20 01:27 PM
Posts: 667 Los Osos, Ca
CKessel
Los Osos, Ca
I also have a Bend Pak. Before I bought it, did some shopping and watched vids. Backyard Buddy showed theirs with a car on it, being moved around on the floor with the dollies installed. I asked the company where I bought my BP from if the BP could do the same. They said yes. Had it put together, put the Coronet on, went to move it and rolled over two out of four dollies. The ones they give you only work with lift only, no car. I ended up making my own out of some heavy wall rectangle, some solid and long bolts to replace the pins. The only thing I reused from the junky ones was the casters. Hard phenolic material, rolls much easier the urethane on concrete. Now, with at least one more person, I can move the car around without issues. 1 1/4" x 1/4" strap for dollies is sketchy. I told the rep from BP at a recent SEMA show about that and she was embarrassed to hear it.
Carl Kessel
Re: 4 Post Car Lift
[Re: TJP]
#2801861
07/27/20 07:55 PM
07/27/20 07:55 PM
Posts: 285 Northern IL
meathead66
Northern IL
Just installed the Triumph 9000 by myself using 2 cherry pickers. Picked it up in Columbus for $3100 with my 18’ car trailer. Best price I found. Low ceiling but I roll around on my adjustable stool. Not too old to lay on my back ....just too old to get back up.
Re: 4 Post Car Lift
[Re: moparjack44]
#2802020
07/28/20 08:41 AM
07/28/20 08:41 AM
Posts: 3,455 Newburgh, NY
Old_Moparz
Newburgh, NY
Lifts aren't cheap but I didn't think Bend Pak was expensive compared to some. I've had mine up for many years & very happy with them. Did an install write up if you care to read it..... Bend Pak Install
Re: 4 Post Car Lift
[Re: Old_Moparz]
#2804152
08/02/20 12:04 PM
08/02/20 12:04 PM
Posts: 3,464 Back in NJ....
EWJ
Back in NJ....
I have an Eagle and a Bend Pak HD9 : BP all the way. 3k delivered when I bought it in 2014. Way heavier and more substantial than the Eagle.
Ed EastCoast Land Yacht Assoc. 1967 Newport Conv: 440/4 speed 1969 GTX: 440/4 speed, TX9/TX9, A34, N96 1970 Super Bee: 383/4 speed, B5/B7 1970 Coronet RT: 440/4 speed, A34, N96 1970 Coronet RT: 440/auto, A36, N96 1970 Road Runner convertible: 383/4 speed TX9/D6XW 1970 GTX: 440+6/727, A32, N96 2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed "The early bird may get the worm, but the 2nd mouse gets the cheese".
