Proportioning valve suggestions
#2792680
07/04/20 03:31 PM
07/04/20 03:31 PM
Posts: 1,487 STL
cdstl
STL
I’m in the process of converting the 65 Satellite to front disc brakes with a dual master cylinder.
The conversion block from Inline Tube is just a connection with no metering. I suppose that this is the time to add a prop valve. I see that Jegs has a simple one for about $35.
Does the valve have to be up front or can it be back by the rear axle. I realize that under the hood would keep it clear if road grime.
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Proportioning valve suggestions
[Re: TJP]
#2792840
07/05/20 06:19 AM
07/05/20 06:19 AM
Posts: 1,487 STL
cdstl
STL
Thanks, that's what I figured.
[Re: cdstl]
#2793038
07/05/20 04:56 PM
07/05/20 04:56 PM
Posts: 4,848 Memphis
HemiRick
Memphis
No reason not to get adjustable one....I've put them in 2 disk brake conversion cars and they work great.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: SportF]
#2793235
07/06/20 06:10 AM
07/06/20 06:10 AM
Posts: 1,487 STL
cdstl
STL
What kind of master do you have? Aluminum? Does your pedal go to the floor when you bleed it? I haven't bled the system yet and I have a 15/16" bore cast iron master cylinder. I ordered a Prop valve from Jegs.
