How much atf+4 / 2012 Grand Cherokee #2790638
06/29/20 12:24 PM
06/29/20 12:24 PM
Penna
70satelliteguy Offline OP
Penna
My users manual does not indicate how much for a trans fluid/filter change.
Thanks Mike
Re: How much atf+4 / 2012 Grand Cherokee [Re: 70satelliteguy] #2792647
07/04/20 01:58 PM
07/04/20 01:58 PM
massachusetts U.S.A.
1969ronnie Offline
1969ronnie  Offline
hi mike , are you also draining or servicing the transfer case ? drive ronnie 6 to 7 qts in trans and mabe 2.5-3 in transfer . pick up a 12 pack to be covered . wrench
Re: How much atf+4 / 2012 Grand Cherokee [Re: 70satelliteguy] #2792678
07/04/20 03:27 PM
07/04/20 03:27 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Just drop the pan and filter , maybe 5 or 6
loosen the valve body slightly lets the convertor drain a tad, add maybe another 1 or 2 qts
