Re: Master cylinder question
[Re: bobs69]
#2792583
07/04/20 11:09 AM
07/04/20 11:09 AM
Posts: 25,791 Rio Linda, CA
John_Kunkel
Rio Linda, CA
What kind of discs up front? What MC do you have now? If the MC still has the residual pressure valve(s) it can cause the disc brakes to drag.
A Mopar tandem disc brake MC from a '67-'78 will bolt right up to the '64 firewall.
[Re: bobs69]
#2792629
07/04/20 01:04 PM
07/04/20 01:04 PM
Posts: 19,402 north of coder
moparx
according to my wagner master catalog, the 73-76 dart manual disc brake master is part #F88787. it has a 1 1/32" bore. the four bolt pattern should be the same to bolt up to your car, but i can't say for sure if that master uses studs or nuts and bolts for attachment. you should be able to cross reference the wagner number to your master cylinder brand of choice.
