Best master cylinder #2787358
06/20/20 10:42 AM
06/20/20 10:42 AM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
What master cylinder is best for a drag car with front disc and drum on back? Thanks
Re: Best master cylinder [Re: bobs69] #2787402
06/20/20 01:01 PM
06/20/20 01:01 PM
Idaho
Runner Offline
Runner  Offline
Idaho
i dont know whats best. but if its in a stock location ive had good luck with these on 3 of my cars. https://www.doctordiff.com/aluminum-master-cylinder-kit.html
Re: Best master cylinder [Re: bobs69] #2787584
06/20/20 10:07 PM
06/20/20 10:07 PM
For what type of drag car? How fast is it in MPH at the finish line, how long is the track length and shut down area, and how much does the car weigh?
Re: Best master cylinder [Re: Cab_Burge] #2792231
07/03/20 09:43 AM
07/03/20 09:43 AM
PA
dixie2bird Offline
dixie2bird  Offline
PA
I'm going to hijack this post if you don't mind. I have the same question. I blew my master cylinder out racing and I'm looking for something a bit more heavy duty.
72 Cuda 340
95 - 100 miles/hr
1/4 mile; not sure how long the shut down area is. It wasn't very long .. hence hard braking
3,000 lbs (maybe lighter - had no interior in it at the time grin
1972 Cuda 340 4-speed
2015 Challenger SRT 392
2015 Jeep Wrangler Unlimited Willy's
Re: Best master cylinder [Re: dixie2bird] #2792250
07/03/20 10:29 AM
07/03/20 10:29 AM
MR_P_BODY Offline
MR_P_BODY  Offline
72 Cuda 340
95 - 100 miles/hr
Your issue isnt the master.. you need bigger brakes... unless you put a larger dia master on.. which is
the wrong thing.. bigger master you have to push the pedal harder to get the same pressure.. a smaller
one will apply more pressure with lesser pedal pressure
wave
Re: Best master cylinder [Re: MR_P_BODY] #2792334
07/03/20 01:14 PM
07/03/20 01:14 PM
72 Cuda 340
95 - 100 miles/hr
wave
iagree Been there done that before I was aware that the same looking master cylinder could come with two different bore sizes and finding out going to bigger was not the correct way to help stop the race car on a short track tsk I found out later I had switch from a 15/16 to 1 1/8 bore size whiney
I had to almost stand on the dang brake peddle to get it to stop shock realcrazyMy current S/P bracket car has dual Willwood master cylinder with 15/16 bore size, my car has dual calipers on the rear end and stops fine at 150.MPH in the 1/4 mile, not so easy on stopping at 120.MPH in the 1/8 mile at our local track shruggy
Re: Best master cylinder [Re: Cab_Burge] #2792385
07/03/20 04:32 PM
07/03/20 04:32 PM
moparx Offline
moparx  Offline
cab, what size bore rear calipers are you using ?
beer
Re: Best master cylinder [Re: moparx] #2792486
07/03/20 11:46 PM
07/03/20 11:46 PM
beer
I have no idea, they where on the car when I got it shruggy I can't remember if their four pistons or six pistons, I think the rotors are under 12.0 inch diameter. I replace the rears several years ago due to them being heat cracked a bunch so I can try and measure them. They are 11 1/4 O.D.
The car is in the trailer at the race track, I think it has the same size four piston calipers on both ends, dual calipers on the rear end. It stops fine so far, hoping to turn it up this year luck
