Fuel injection can be dangerous.
#2791752
07/02/20 12:37 AM
07/02/20 12:37 AM
Posts: 782 wine country
8urvette
wine country
I just want to share this story with you guys to help emphasize the dangers of fuel leaks in high pressure fuel injection, and always carry a fire extinguisher with you. I have another little hot rod car, its a turbo charged honda.
I was driving my car down the highway, I had just done a big 2nd gear and 3rd gear pull, lots of tire smoke, and spinning of the slicks. Once I got out of it I noticed my AFRs started to go really lean, like 19 to 1. The car started losing power, and the AFRS went off the chart. I started to play with the throttle to see if this was just a weird issue.
Since I was on the highway, there wasn't any easy spot for me to pull over. I had to drive it about 1 mile to exit and get off the road.
I stop and pop the hood, the entire engine bay is covered in fuel- The turbo charger, the turbo manifold, I mean everything. The fuel was literally pouring out of the engine compartment. There was a huge puddle underneath it.
The fuel pressure regulator bolts backed out allowing a 450LPH pump to unload fuel through the loosened fitting. I think the only reason it didn't catch Fire was I am running E85... or I am just that dang lucky. The car had spent 7 hrs on a dyno and has driven hundreds of miles before this issue. NO idea why is loosened up. I did not have a fire extinguisher in the car had it caught on fire.
After filling the tank up and calculating how many miles I had driven, and how many MPGS i get I calculated I Pumped 5 gallons of fuel on my engine.
I now have a fire extinguisher. Be careful
Re: Fuel injection can be dangerous.
[Re: 8urvette]
#2791782
07/02/20 07:24 AM
07/02/20 07:24 AM
Posts: 8,037 Tulsa OK
Bad340fish
Tulsa OK
Yikes, glad nothing bad happened!
That can happen to any combo really not just fuel injection. Most regulators are the same for EFI or Carb they just use a different spring.
68 Barracuda Formula S 340
[Re: 8urvette]
#2791966
07/02/20 04:58 PM
07/02/20 04:58 PM
Posts: 22,738 Bitopia
jcc
Bitopia
1. Yes you were very lucky 2. ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) for sharing, but the common "It won't happened to me" still rules 3. Never gave much thought to the increase safety of E85, but I Think you are right 4, Any fuel leak is a serious issue, but at 40+lbs its way way worse.
[Re: moparx]
#2799951
07/22/20 07:37 PM
07/22/20 07:37 PM
Posts: 1,467 Martinsville, IN
cdwmotorsports
Martinsville, IN
i wonder if the aeromotive brand regulators have the same problem ? I hope not as my fuel pump, filters and regulator are all now Aeromotive.
eBay-cdwmotorsports
