Champion Radiator vs. Wizard Radiator #2790267
06/28/20 12:11 PM
06/28/20 12:11 PM
Rochester, New York
GregY Offline OP
GregY  Offline OP
Rochester, New York
Hi All,
I am planning to install a 22-inch wide aluminum 2-core radiator in my 1971 Charger to (hopefully) drop the coolant temp in warmer weather. It has a flow cooler water high flow pump, high flow 180 degree thermostat, mechanical fan (non-clutch) with plastic shroud, and the original 22-inch 4-core factory radiator. It's a 440 with headers.
My two realistic choices appear to be the Champion from Mancini ($200, but the tubes are only 3/4-inch), or Wizard Cooling ($540 but it has 1-inch tubes). I would rather spend $200 than $540, but I don't want to go cheap and then regret it either. I am planning on sticking with my mechanical fan and shroud, and only upgrading to an electric fan if it still needs help.
I also looked at a crossflow generic radiator from Summit, but to get a 22-inch wide core, I need the 26-inch wide radiator and then I start to run into fitment issues (mounting it, redoing the tranny cooler lines, making the cooler lines fit with the battery tray right there, what to use for radiator hoses, etc.). I am not really a fabricator, although I could probably make it work if I had to. That one is $215 (https://www.summitracing.com/parts/sum-381425) plus $30 bucks in mounting hardware, plus new hoses, etc. For $275 or so, I would probably have a better radiator than the Champion for a little more money and half the price of the Wizard, but with a lot of potential headaches. I could get a smaller radiator, but not taking full advantage of the 22-inch core width that I have seems foolish.
I know there are a ton of radiator posts, I have read all of them. If anyone has any specific advice they could offer me, I would appreciate it.
Thanks.
Greg
Re: Champion Radiator vs. Wizard Radiator [Re: GregY] #2790283
06/28/20 12:42 PM
06/28/20 12:42 PM
central il.
second 70 Offline
second 70  Offline
central il.
I have a 3 core 22" champion in my 600hp hemi cuda and it cools great. Only had to drill one lower hole the other 3 were perfect.
Re: Champion Radiator vs. Wizard Radiator [Re: second 70] #2790315
06/28/20 01:51 PM
06/28/20 01:51 PM
Pattison Texas
CSK Online shake_head
CSK  Online Shake_Head
Pattison Texas
ECP is what I have & works great 2 1in rows.
Re: Champion Radiator vs. Wizard Radiator [Re: CSK] #2790327
06/28/20 02:13 PM
06/28/20 02:13 PM
MN
W
Willie68coronet Offline
W
MN
I got a 26 inch from auto city classic (autocity1958 on ebay). It's a two core with 1-1/8" tubes. Looks pretty factory for a aluminum radiator and cools my 600+ hp 440 with a mancini hi-volume pump, MP housing, milodon 160 hi flow stat, stainless steel flex fan and plastic mopar shroud. It bolted right in my coronet with no mods or drilling. I'm very impressed with it. I cruised at stop and go traffic on a hot an humid day and on the freeway at 70mph and havent seen anything higher than 180-185 degrees I think they offer 22 inch rad's as well.
the rad I bought
'68 Coronet 500 w/ Indy EZ-1 headed 446, 727 trans, 9" rear
First day at the track with SUV street tires and no traction: 1.688 60', 7.24 @ 101.79 in the 1/8 mile
Great customer service from: DominicThumper Carbs, B3 racing engines, Porter Racing Engines, A-1 torque converter's, Quick Performance, Racer Brown Cams, R&R Performance, Manton pushrods
Re: Champion Radiator vs. Wizard Radiator [Re: second 70] #2790356
06/28/20 03:18 PM
06/28/20 03:18 PM
Rochester, New York
GregY Offline OP
GregY  Offline OP
Rochester, New York
Is that shroud a Champion piece?
Re: Champion Radiator vs. Wizard Radiator [Re: GregY] #2790388
06/28/20 04:29 PM
06/28/20 04:29 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
From personal experience, the 3/4 inch tubes on the Champion radiator are too small and plug easily.
Once they're plugged, there's no way to unplug them so you end up buying another radiator.
Go with a radiator with a larger tube size from the start.
There are plenty of vendors on ebay that sell the larger tube size radiators for the $200 price range that are direct bolt in and resemble the factory radiator.
Factory shrouds bolt directly on them and they cool perfectly.
Re: Champion Radiator vs. Wizard Radiator [Re: GregY] #2790443
06/28/20 07:10 PM
06/28/20 07:10 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I have had a couple of the Champion radiators. They were both twisted. One was so bad I couldn't use it at all. The other I got to work with some mods.
It did cool okay.
Master, again and still
Re: Champion Radiator vs. Wizard Radiator [Re: DaveRS23] #2790455
06/28/20 07:40 PM
06/28/20 07:40 PM
Spring Hill Fl
65Fury440 Offline
65Fury440  Offline
Spring Hill Fl
I went from a stock 383 22" in my car to an aluminum 2 core- 1 1/2 tubes,
It was fine with the 440, but when the stroker went in, it was not keeping up with the thermostat setting
. I would get up to 190 at a light, and take 5 or so miles of highway speed before it would cool back down.
I went to a 4 row Champion, huge difference. Do it once and go 4 row,
Re: Champion Radiator vs. Wizard Radiator [Re: GregY] #2790486
06/28/20 08:20 PM
06/28/20 08:20 PM
Alberta Canada
PossessedDuster Offline
Alberta Canada
I had to send my 22" Wizard back twice. I got it and noticed that the billet neck was cracked on the sealing surface for the rad cap. Was told this can happen from the heat of welding.
Shipped it back for repairs. When I got it back put it in and it leaked badly from the seams on the upper tank. They had to pull the top tank off to replace the filler neck and didn't weld it right. You would think it was pressure tested but nope. Sent it back again for repairs and its been good since then. However I should have gone with a Glen-ray or Griffin direct fit instead.
Re: Champion Radiator vs. Wizard Radiator [Re: PossessedDuster] #2790533
06/28/20 10:43 PM
06/28/20 10:43 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
My 22" Wizard has been perfect since I bought it three years ago on sale with free shipping
Even the factory fan shroud fit perfect
383/432 Stroker
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Champion Radiator vs. Wizard Radiator [Re: bee1971] #2790534
06/28/20 10:55 PM
06/28/20 10:55 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I've never had a problem with a Griffin or a Champion (both in non-stock cars).
But I prefer the more stock-looking ones if not going strictly OEM.
Re: Champion Radiator vs. Wizard Radiator [Re: GregY] #2790540
06/28/20 11:24 PM
06/28/20 11:24 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
HI
AUTOCITY 1958 E BAY ! look them over , got one for my 1966 belvedere hemi , fan shroud from a an e body bolted right on !
Re: Champion Radiator vs. Wizard Radiator [Re: calrobb2000] #2790648
06/29/20 12:52 PM
06/29/20 12:52 PM
Rochester, New York
GregY Offline OP
GregY  Offline OP
Rochester, New York
Originally Posted by calrobb2000
HI
This is actually what I ended up going with, thanks for the help everyone.
Greg
Re: Champion Radiator vs. Wizard Radiator [Re: GregY] #2790677
06/29/20 02:38 PM
06/29/20 02:38 PM
central il.
second 70 Offline
second 70  Offline
central il.
No it's an aftermarket half shroud. https://www.summitracing.com/parts/spe-4348?rrec=true
Re: Champion Radiator vs. Wizard Radiator [Re: 65Fury440] #2790856
06/29/20 11:42 PM
06/29/20 11:42 PM
Watertown, WI
MikeyT Offline
MikeyT  Offline
Watertown, WI
I really liked my 26 Champion I had in my old 1970 Dodge superbee clone. It really cooled well. I have not had experience with Wizard.
1969 Dodge Dart Swinger
Re: Champion Radiator vs. Wizard Radiator [Re: MikeyT] #2791513
07/01/20 01:49 PM
07/01/20 01:49 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I went with the 4 row triple pass US copper brass US radiators, I wont know how it runs because my body guy screwed up and welded the core brace too shallow and the radiator wont fit. Its a little on the expensive side at $980...but they are supposed to be the best.
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Champion Radiator vs. Wizard Radiator [Re: astjp2] #2791547
07/01/20 02:59 PM
07/01/20 02:59 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
I also went with the US Radiator... two 1" rows of aluminum, 22" width for my opening, triple pass.... will be running my new SB engine soon this summer... hope all will be A-OK.
Price wasn't bad... around $550 shipped.
Re: Champion Radiator vs. Wizard Radiator [Re: Mopar Mitch] #2798190
07/18/20 08:11 AM
07/18/20 08:11 AM
Rochester, New York
GregY Offline OP
GregY  Offline OP
Rochester, New York
I put my EBAY "Autocity 1958" 22-inch aluminum 2 core radiator in my 1971 Charger R/T and went to the track yesterday in 82-84 degree ambient air temp and the car ran 180 degrees the whole way down (50 miles), in the lanes, after passes, etc., etc. Two weeks ago with my stock radiator I tried to go in the same temperature air and never even made it to the track, was running 220 degrees and climbing on the drive down.
I have never been happier with a $250 purchase! Thank you for all of the help.
Greg
Re: Champion Radiator vs. Wizard Radiator [Re: GregY] #2798248
07/18/20 11:33 AM
07/18/20 11:33 AM
moparx Offline
moparx  Offline
happy to hear it worked for you ! up
thanks for the update.
beer
