440 id help #2790265
06/28/20 12:03 PM
06/28/20 12:03 PM
Southeastern Ohio
1st_charger Offline OP
Southeastern Ohio
I picked up a 440 the other day and I'm looking for some help on identifying it. Its cast date is 4/2/68, the front pad is pitted but I can see HP2 on it but thats it the rest of the pad is pitted to bad to read. Where the vin would be on the side is blank? And I found a stamping on the bottom of the block beside the rear main seal starter side PT440P24980783. Does anyone know what that number is? The opposite side just has a B stamped on it.
Thanks for your help
Re: 440 id help [Re: 1st_charger] #2790273
06/28/20 12:21 PM
06/28/20 12:21 PM
AndyF Offline
AndyF  Offline
If that is all you can find then you won't get too far. Late casting for the '68 model year but the 10,000 day number makes it seem like it did get used in a 1968 car. Would've been one of the very last ones for the '68 model year.
Re: 440 id help [Re: 1st_charger] #2790278
06/28/20 12:27 PM
06/28/20 12:27 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
4*2*68 cast date (Monday)
HP2 = high performance (assembled) 2nd shift
PT440P24980783
PT = Trenton, MI engine assembly plant
440 = cu.in.
P = premium fuel
2498 = engine assembly date = Thursday May 30, 1968
0783 = engine unit number
the VIN should be stamped by the oil sending unit upper rear of block scope
it's a 1968 model year 440HP engine (375hp)
Re: 440 id help [Re: 6bblgt] #2790286
06/28/20 12:46 PM
06/28/20 12:46 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
I thought the HP engines / engines that came on an R/T were stamped with an "S" PT440S special and the 350 horse got the "P"
Re: 440 id help [Re: R/T1968R/T] #2790308
06/28/20 01:23 PM
06/28/20 01:23 PM
Southeastern Ohio
Southeastern Ohio
Ok so I found the numbers at the oil sender and I can read A314791
Re: 440 id help [Re: R/T1968R/T] #2790335
06/28/20 02:38 PM
06/28/20 02:38 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
good catch iagree pics would help work PT440P = 350hp & NO "HP" or VIN stamp and PT440S = 375hp & both "HP" & VIN stampings
the partial VIN A314791 would've been from an early June '68 "scheduled" Coronet R/T or GTX
Re: 440 id help [Re: 6bblgt] #2790386
06/28/20 04:24 PM
06/28/20 04:24 PM
Southeastern Ohio
Southeastern Ohio
Great so now I'm confused, is it an HP block without the S? Sorry I've tried to take pics with my phone and post but it always says they are to big.
Re: 440 id help [Re: 1st_charger] #2790441
06/28/20 07:07 PM
06/28/20 07:07 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
only "HP" 440s were installed at Lynch Rd. for '68 "8A314791" (NO 350hp versions - all B-bodies: Coronet R/T & GTX ONLY))
only "HP" engines were VIN stamped in 1968
is it clearly a "P"? scope if so, it is an assembly line mistake or the other stampings are "after-the-fact" hammer email the pics & I'll post them dhead68@hotmail.com
Re: 440 id help [Re: 6bblgt] #2790998
06/30/20 01:44 PM
06/30/20 01:44 PM
Southeastern Ohio
Southeastern Ohio
Thanks ill have to take the pictures again and ill send them,
Re: 440 id help [Re: 1st_charger] #2791518
07/01/20 02:00 PM
07/01/20 02:00 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
it does appear to be a Lynch Rd. 1968 440HP with a "PT440P" VS. the expected "PT440S" shruggy
thumbnail_20200630_202529.jpgthumbnail_20200630_202604.jpgthumbnail_20200630_202641.jpgthumbnail_20200630_202659.jpg
Re: 440 id help [Re: 6bblgt] #2791521
07/01/20 02:03 PM
07/01/20 02:03 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
the blank VIN pad & a couple earlier in the model year PT440S stampings scope
thumbnail_20200630_202715.jpgmoparts PT440S22852428 10-30-67 vs PT440S23660740 1-19-68.jpg
