440 Source Stealth head valve guides
#2790090
06/27/20 08:29 PM
06/27/20 08:29 PM
Posts: 46 Medford, OR
carrman
Medford, OR
I've got a set of the Stealth heads from my now deceased 451, and the machine shop says my exhaust valve guides were a looser fitting in the heads than he would like, and the intakes were "meh". So, we need a set of guides. 440 says they are .530 OD, but the guides we pulled out measure out to .542". Has anyone here ever replaced valve guides in the Stealth heads, and if so, what was used?
Re: 440 Source Stealth head valve guides
[Re: carrman]
#2790130
06/27/20 10:10 PM
06/27/20 10:10 PM
Posts: 2,872 Pattison Texas
CSK
Pattison Texas
Dave I replace mine with some from Edelbrock , not sure of the size. but they were the same
[Re: CSK]
#2790136
06/27/20 10:17 PM
06/27/20 10:17 PM
fast68plymouth
So. Burlington, Vt.
The Ede guides are a nominal .545
