1974 Cuda front & quarter glass alignment HELP! #2789882
06/27/20 02:27 PM
06/27/20 02:27 PM
N
NavyDoc Offline OP
NavyDoc  Offline OP
N
Afternoon everyone. So im at my wits end. I Cant get my front and quarter glass to seal tightly against each other..I have tried everything i can think of with no luck. There has to be something im missing or some trick or something. Any help would be greatly appreciated. God bless!
Chris "2strong" Turner 74' Barracuda JESUS IS LORD!
Re: 1974 Cuda front & quarter glass alignment HELP! [Re: NavyDoc] #2789890
06/27/20 02:41 PM
06/27/20 02:41 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Get, or print out, or just look at, the FSM on glass alignment.
I'm not an E-body expert, but similar logic & parts apply to most Mopars:
Looks to me like the window channel (aka "guide") for in/out is maladjusted, too far towards the center of the car.
That tips the top of the door glass out.
Typically that's the rear channel, with a bolt head & slotted hole at the rear door jamb face.
There may also be another adjustment on the regulator or front channel. You'll need the trim panel off, of course.
There's another adjustment for topping and bottoming out, but get the angle corrected first.
Quarter glass also has adjustments, need to pull rear seat & interior trim panels to access that.
Re: 1974 Cuda front & quarter glass alignment HELP! [Re: topside] #2790032
06/27/20 07:10 PM
06/27/20 07:10 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
iagree The quarter glass looks OK the door glass needs to come in at the top.
Re: 1974 Cuda front & quarter glass alignment HELP! [Re: stumpy] #2790181
06/28/20 01:37 AM
06/28/20 01:37 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Bottom of vertical tracks have slotted holes bottom of door to do that # 5 & 6 in pic
Re: 1974 Cuda front & quarter glass alignment HELP! [Re: PhillyRag] #2790205
06/28/20 07:42 AM
06/28/20 07:42 AM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
to move the glass in at the top. the tracks need to be pushed out at the bottom.
perception is 90% of reality
Re: 1974 Cuda front & quarter glass alignment HELP! [Re: Mr T2U] #2790434
06/28/20 06:22 PM
06/28/20 06:22 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
iagree
