Re: new Best [Re: 10secGTX] #2789289
06/25/20 10:57 PM
06/25/20 10:57 PM
AndyF Offline
AndyF  Offline
133 mph at 3900 lbs in a car shaped like a barn door is pretty decent. Your ET and MPH are pretty close to what the chart calls for so it looks like your chassis is working good. Should be a fun ride and I'm sure you'll pick up some speed when you get a nice weather day. Come out here to Oregon when the weather is 70 degrees with DA of 100 feet and it will run great!
Re: new Best [Re: 10secGTX] #2789360
06/26/20 09:12 AM
06/26/20 09:12 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Originally Posted by 10secGTX
Hi all, It's been a while ...
I finally got a chance to get back to the local Track, with a couple upgrades 1. New Ignition a Daytona Sensors
2. New Gears 4.30 formerly 3.90
results 1st pass Hot as Hell engine was 200 degree's on the tree 10.07 @ 131 1.46 60'
2nd pass engine cooled 9.99 @ 133 1.44
3rd pass temp was down outside and removed the hood added carb spacer 9.84 @ 131 1.41 60' !!!!!!
That's flying for that big tub....Congrats. What's the engine combo?
Interesting you're 60ft seems light and so does your mph to go 9.84, so the mid range has to be really pulling...What are you shifting at, are you short shifting it?
I can tell you, there is more in that combo...If I had to guess, I would looking to see if its lean on the top end, and adding more timing for the 60ft...Where is the timing mark on the plugs?
Re: new Best [Re: Dragula] #2789469
06/26/20 01:08 PM
06/26/20 01:08 PM
moparx Online content
moparx  Online Content
YEEHAAWWW !!! up good job !
beer
Re: new Best [Re: Dragula] #2789708
06/26/20 10:42 PM
06/26/20 10:42 PM
Cleveland Ohio
10secGTX Offline OP
10secGTX  Offline OP
Cleveland Ohio
I have to confess .... if you look at the best pass mph I lifted. Things are happening way faster than when it ran 10.60's obviously, I shift at 6800 and it was pulling BUT it seemed like the shift light was on forever !!! timing is 34 and we didn't pull a plug so yes I hope there is more in it. Andy F where did this engine stop making power ? I have the limiter at 7500. I will have more DATA as soon I can get my act / seat time together
The Engine is Andy's former 514 Dyno engine
Re: new Best [Re: 10secGTX] #2789710
06/26/20 10:52 PM
06/26/20 10:52 PM
AndyF Offline
AndyF  Offline
Peak power with my ported intake and 2 inch headers was in the 6800 to 7000 range. Just depended on which parts we had on the engine. If you're still running the OOTB Super Victor then it might be nosing over a little sooner. I was running a 2000 cfm throttle body and I think you have a 1150 Dominator so that might be knocking a little off. I'd think you're in good shape if you are shifting at 6800 and then running out the back door at 7000. You'll just need to keep an eye on the valve lash and the plugs until you get some more laps on it.
Re: new Best [Re: AndyF] #2789828
06/27/20 11:31 AM
06/27/20 11:31 AM
Cleveland Ohio
10secGTX Offline OP
10secGTX  Offline OP
Cleveland Ohio
I had the Intake cleaned up nothing like Wilsons work but better than OOTB, We still have the larger intake rockers to try also, so I will keep updates
Re: new Best [Re: 10secGTX] #2789836
06/27/20 11:42 AM
06/27/20 11:42 AM
Cleveland Ohio
10secGTX Offline OP
10secGTX  Offline OP
Cleveland Ohio
Time slip
Re: new Best [Re: 10secGTX] #2789930
06/27/20 04:06 PM
06/27/20 04:06 PM
Monrovia, So-Cal, USA
racerhog Offline
racerhog  Offline
Good Job !!!! smile
Bob(Cowboy)Hogan
Monrovia So-Cal
Re: new Best [Re: 10secGTX] #2789964
06/27/20 04:56 PM
06/27/20 04:56 PM
AndyF Offline
AndyF  Offline
After looking at the time slip some more I agree that you have a bit left in the car. The 60 ft is a little soft for 9.84 and the mph is slow for 9.84. So if you got it to launch harder you would pick up some time and if you run it WOT out the back door it will pick up a little. That time slip looks like you got on it hard mid-track where it picked up time and speed but then you lifted at the end. Nothing wrong with that since it is one of the first times you've had that combo to the track. Get a few more passes under your belt with that engine and you'll pick up a little bit more.
Re: new Best [Re: 10secGTX] #2790354
06/28/20 03:17 PM
06/28/20 03:17 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Very impressive Fran!!
Re: new Best [Re: ProSport] #2790569
06/29/20 06:26 AM
06/29/20 06:26 AM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
Right On Franny!
Re: new Best [Re: 10secGTX] #2790619
06/29/20 11:27 AM
06/29/20 11:27 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
What an exciting move to begin a crazy year.Not many people get the chances to grow with the sport and I am excited for your future both in family and your car.Show me how it is done Fran and I will be cheering you on.
Re: new Best [Re: 10secGTX] #2790674
06/29/20 02:37 PM
06/29/20 02:37 PM
NE Ohio
DoubleD Online content
DoubleD  Online Content
NE Ohio
Time slip
- Here is my time slip from the next day out at 42 - you must be lifting before the last MPH cone incrementals are pretty close - you are a little quicker starting at at the 330 - We are pretty close in weight at around 3800 or so - Congrats on the new best - you are in the nines!
