Tires bounce in burnout
#2788999
06/24/20 09:58 PM
06/24/20 09:58 PM
Posts: 4,688 On the parachute mount
n20mstr
Tires bounce in burnout and vibration before finish line .
Tire balance or driveshaft/u-joints?
Hoosier radials they are balanced and take a lot of weight Driveshaft is Denny’s nitrous ready , been in car 10 years . Approx 500 passes and who knows street miles
....BAD A$$ STREET CAR.....
Re: Tires bounce in burnout
[Re: n20mstr]
#2789078
06/25/20 08:10 AM
06/25/20 08:10 AM
Posts: 13,375 Marion, South Carolina [><]
an8sec70cuda
Tony, I'd be leaning more towards it being a tire issue. I've twisted driveshafts in the past and only had a vibration through 1st and 2nd gear...not noticeable anywhere else. Once in high gear, it smoothed right out. Had this happen twice. Last year I had a slight vibration in 2nd gear only...turned out to be wear in the U joints. New U joints and it's smooth as silk again.
[Re: BigBlockGTS]
#2789083
06/25/20 08:17 AM
06/25/20 08:17 AM
n20mstr
n20mstr- I suspect you have forgotten more than me but I spoke with a real good local driveline shop recently that did drag racing stuff- He said driveshafts do wear out. I don't know your power level but 500 passes is a decent number and it could be that it twisted and is now out of balance. Its a small block duster street car . 400+ ? Hp . Runs 11 teens at 120. I think It’s the tires. I also think the driveshaft needs maintenance. It’s been in the car for ten years . He races multiple classes most times and like I said it’s got well over 500 passes on it most of them 11.50 to 11 teens . It’s a 3200lb street car . It’s got some street miles on it also .
[Re: an8sec70cuda]
#2789085
06/25/20 08:21 AM
06/25/20 08:21 AM
n20mstr
Tony, I'd be leaning more towards it being a tire issue. I've twisted driveshafts in the past and only had a vibration through 1st and 2nd gear...not noticeable anywhere else. Once in high gear, it smoothed right out. Had this happen twice. Last year I had a slight vibration in 2nd gear only...turned out to be wear in the U joints. New U joints and it's smooth as silk again. He has balanced the tires twice now . On a spin balancer . I told him call Hoosier and see if he did something wrong . Maybe they can only be bubble balanced ? Or maybe something wrong with these tires. They take 9-10oz to balance .even tried moving them around on the rim
[Re: n20mstr]
#2789087
06/25/20 08:23 AM
06/25/20 08:23 AM
Posts: 12,171 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Check your tires for roundness. We see more and more tires that are egg shaped. And no amount of weights will offset it. I have a pair of MT drag radials that are so out of round that they will shake the fillings out of your teeth by 60mph.
Master, again and still
[Re: DaveRS23]
#2789091
06/25/20 08:49 AM
06/25/20 08:49 AM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Put the car on stands/ hoist. Run the car in low gear and look for oval running tire or wheel. It would not be unusual to see a powerful radial car to have bent wheels or axles.
[Re: n20mstr]
#2789092
06/25/20 08:55 AM
06/25/20 08:55 AM
Posts: 165 W. Pa
usp4u
W. Pa
Tony, I'd be leaning more towards it being a tire issue. I've twisted driveshafts in the past and only had a vibration through 1st and 2nd gear...not noticeable anywhere else. Once in high gear, it smoothed right out. Had this happen twice. Last year I had a slight vibration in 2nd gear only...turned out to be wear in the U joints. New U joints and it's smooth as silk again. He has balanced the tires twice now . On a spin balancer . I told him call Hoosier and see if he did something wrong . Maybe they can only be bubble balanced ? Or maybe something wrong with these tires. They take 9-10oz to balance .even tried moving them around on the rim If I had a tire that HAD to have that much weight....I'd throw it out.
[Re: TRENDZ]
#2789095
06/25/20 09:08 AM
06/25/20 09:08 AM
n20mstr
Put the car on stands/ hoist. Run the car in low gear and look for oval running tire or wheel. It would not be unusual to see a powerful radial car to have bent wheels or axles. I don’t know if I would say it’s “powerful” lol but it’s got an 8.8 from an explorer under it . Stock axles . We are going to run it on stands see what the tires rims axles are doing
[Re: n20mstr]
#2789109
06/25/20 10:03 AM
06/25/20 10:03 AM
an8sec70cuda
I'd definitely do what Trendz suggested! I forgot to mention a couple years ago I also had a vibration that turned out to be twisted axles. Again, wasn't noticeable at speed. I found it by letting the car idle in gear on jackstands. https://www.youtube.com/watch?v=u7en1p9e7iU
[Re: usp4u]
#2789110
06/25/20 10:10 AM
06/25/20 10:10 AM
Posts: 9,858 MI, usa
dvw
MI, usa
He has balanced the tires twice now . On a spin balancer . I told him call Hoosier and see if he did something wrong . Maybe they can only be bubble balanced ? Or maybe something wrong with these tires. They take 9-10oz to balance .even tried moving them around on the rim [/quote]
If I had a tire that HAD to have that much weight....I'd throw it out. [/quote]
Apparently you've never balanced a bias ply slick Doug
[Re: dvw]
#2789129
06/25/20 11:33 AM
06/25/20 11:33 AM
Posts: 43,230 Bend,OR USA
Cab_Burge
If I had a tire that HAD to have that much weight....I'd throw it out. [/quote] Apparently you've never balanced a bias ply slick Doug [/quote]
[Re: Cab_Burge]
#2789178
06/25/20 02:47 PM
06/25/20 02:47 PM
Posts: 165 W. Pa
usp4u
W. Pa
If I had a tire that HAD to have that much weight....I'd throw it out. Apparently you've never balanced a bias ply slick Doug [/quote] [/quote] nope. that sound ridiculous
[Re: usp4u]
#2789204
06/25/20 05:14 PM
06/25/20 05:14 PM
Posts: 2,115 Byron, NY
W.I.N. Racing
Byron, NY
Just mounted and balanced these Brand New .... 7oz... I've seen that much and more, more times than not.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: usp4u]
#2789240
06/25/20 07:39 PM
06/25/20 07:39 PM
Cab_Burge
I have a old bubble balancer along with a really old(1950 tech.) mechanical tire mounting machine. I replaced Hoosier, they have a bubble on one tire at the edge of the where the tread would be 13.5x32x15 W slicks on my S/P car this winter with a new set of Goodyear 15x33x15. I did all the work here in my shop and when it came time to balance the new tires I had a really hard time balancing these tires on my old bubble balancer, the rims are a old set of Monoque 15x15 with 3.5 inch back spacing. I mounted and balanced the Hoosier and I don't remember having the same issue as these Goodyear, the Goodyears needed very little weight, maybe 2.5 to 4.0 ounces per tire so maybe their not bad. I have ran them in the 1/4 mile(147+MPH) with no issues that I noticed
[Re: Cab_Burge]
#2789340
06/26/20 07:14 AM
06/26/20 07:14 AM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
WE HAVE A LOAD FORCE BALLANCER AND YOU CAN GET IT TO BALLANCE BUT THE LOAD FORCE MAY BE WAY OUT(EGG SHAPE). WE HAVE SEEN 25-50 LBS OF LOAD FORCE.
JAKES AUTOMOTIVE
