I've had the same Prothane brand of poly mount in my cuda since 1997. Started out as a very mild 440 daily driver and now makes well over 1k hp. Only trans case I hurt was when a stock clutch drum exploded in 2008...the entire trans case had to be swept up off the first 20 feet of the track.
