Page 4 of 5 1 2 3 4 5
Re: Spool, truetrac, clutch sure grip or other for street/strip? [Re: GY3] #2788673
06/23/20 11:04 PM
06/23/20 11:04 PM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
Originally Posted by GY3
Funny, this thread is 4 years old!
What I ended up doing was going to a Dana 60 with a Dr. Diff spool and axles. I couldn't be happier!
This car sees a lot of street miles and gets to the track probably 5-6 times during the Summer. Only issues are with tight parking spaces but I can live with that.
I'm now spraying a 200 shot on top of what I was doing and everything works great!
The only thing I will recommend is throwing the wheel studs that come with the Dr. Diff axles in the trash and replacing with something like Strange. They were bending.
I have the same set up from Dr Diff in my Savoy . How are your wheel studs bending?
2 kids and a dog
Re: Spool, truetrac, clutch sure grip or other for street/strip? [Re: TonyS451] #2788729
06/24/20 08:14 AM
06/24/20 08:14 AM
an8sec70cuda Offline
The ONLY time I've not wanted a spool is when trying to push the car w/ the front wheels turned.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Spool, truetrac, clutch sure grip or other for street/strip? [Re: an8sec70cuda] #2788743
06/24/20 09:35 AM
06/24/20 09:35 AM
Washington
hemienvy Online content
hemienvy  Online Content
Washington
Spool Guys:
Just wondering if you have wide tires or "normal" width, I'm wondering how the rear tire width
with a spool affects drivability. I'm looking at doing one car with 18.50 tires.
Re: Spool, truetrac, clutch sure grip or other for street/strip? [Re: hemienvy] #2788755
06/24/20 10:29 AM
06/24/20 10:29 AM
Odessa, Fl
blowndart Offline
blowndart  Offline
Odessa, Fl
I ran a spool with 18.5 tires on the street for awhile. It wasn't bad. I switched to a locker, but a spool will work.
Re: Spool, truetrac, clutch sure grip or other for street/strip? [Re: blowndart] #2788756
06/24/20 10:33 AM
06/24/20 10:33 AM
central il.
second 70 Offline
second 70  Offline
central il.
Love my s trac
Re: Spool, truetrac, clutch sure grip or other for street/strip? [Re: TonyS451] #2788795
06/24/20 12:16 PM
06/24/20 12:16 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
Big torque and crap quality studs that weren't Grade 8 like they were marked.
'63 Dodge 330
11.19 @ 121 mph
Re: Spool, truetrac, clutch sure grip or other for street/strip? [Re: an8sec70cuda] #2788796
06/24/20 12:18 PM
06/24/20 12:18 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
No doubt! A couple of degrees of steering angle and you're screwed! One of the tracks we go to has a 90* right turn in the staging lanes and then another to get to the burnout box. It gets fired up to move it. runaway
'63 Dodge 330
11.19 @ 121 mph
Re: Spool, truetrac, clutch sure grip or other for street/strip? [Re: GY3] #2788818
06/24/20 01:34 PM
06/24/20 01:34 PM
NC
440Jim Offline
440Jim  Offline
NC
What is the practical experience with the warning from the Strange S-trac manual:
Quote
Warning: In extreme situations damage to the unit can occur when one tire spins excessively fast
compared to the other tire. An example of this would be when leaving the water box during a burnout.
Typically one tire will dry up faster than the other creating an unequal traction situation which can cause
an excessive difference in tire speeds. Care should be taken to avoid this situation.
Re: Spool, truetrac, clutch sure grip or other for street/strip? [Re: 440Jim] #2788822
06/24/20 01:47 PM
06/24/20 01:47 PM
Kirkland, Washington
Pacnorthcuda Offline
From a traction perspective that’s exactly what we want a differential traction device to prevent!!!
Re: Spool, truetrac, clutch sure grip or other for street/strip? [Re: GY3] #2788824
06/24/20 01:52 PM
06/24/20 01:52 PM
Martinsville, IN
cdwmotorsports Offline
Martinsville, IN
I have a new Auburn unit in the car (complete 3rd member from Manciniracing) that's already starting to make noises going around corners. Less than 2k miles. down
It's in an 8 3/4 with 3.55 gears and I'm pushing 600 horsepower with ET Street Pro's.
I'm not a fan of the Detroit locker because of the noises it makes in a friend's 9 inch.
I've thought about a spool but not excited about corners on the street with one.
Is the truetrac okay for this level of horsepower and sticky tires?
I've started gathering Dana 60 parts and may just upgrade the whole rear. hammer weld
In my 8.75 I just swapped from a 2.76 single track to a 3.23 suregrip. It was/is only there until I get around to pulling it and swapping in my freshly built 3.91 spool rear. I run an B engined Demon it mostly sees and will continue to see street duty with some racing here and there. I'm hoping at least a stage or two of Drag Week is in that mix this year.
When I build my 512 I may swap to a 60 based rear.
eBay-cdwmotorsports
Re: Spool, truetrac, clutch sure grip or other for street/strip? [Re: cdwmotorsports] #2789044
06/25/20 12:02 AM
06/25/20 12:02 AM
Canada
CrAzYMoPaRGuY Offline
Canada
Should I assume the Eaton TrueTrac is still hit and miss and to be avoided?
Powerlocker- anybody have good/bad stuff I should know? lol There has been a powerlocker in the car for years and years, I've never had trouble with it....
I know....
Yet lol
CrAzYMoPaRGuY
Re: Spool, truetrac, clutch sure grip or other for street/strip? [Re: an8sec70cuda] #2789782
06/27/20 09:25 AM
06/27/20 09:25 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I ran a spool years ago in my bracket car and loved it for a race car. The one thing I don't like about them is if you have to have the car pushed as then it feels like you put the brakes on when turning. That's why I went with the Detroit Locker for my street car. And its been working fine for about 9 years. Ron
Re: Spool, truetrac, clutch sure grip or other for street/strip? [Re: 383man] #2789824
06/27/20 11:25 AM
06/27/20 11:25 AM
AndyF Online content
AndyF  Online Content
I have a Detroit Locker in the Duster but I'm going to swap it for an S Trac. The Locker is noisy and sometimes it does something weird when I'm not expecting it. Nothing super serious, just a wiggle when I get out of the throttle or something like that. Can be a little spooky if you're coming around a corner or going fast.
Re: Spool, truetrac, clutch sure grip or other for street/strip? [Re: AndyF] #2789853
06/27/20 12:57 PM
06/27/20 12:57 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Andy how does the S Trac work ? Is it a posi type of unit ? Thanks , Ron
Re: Spool, truetrac, clutch sure grip or other for street/strip? [Re: 383man] #2790202
06/28/20 07:31 AM
06/28/20 07:31 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
We have a Detroit locker in our Dana 60 in a 3900lb (W/D) E body. It works really well, no noises, no shimmy when on and off the throttle. I phoned round looking for something to take 950ft/lb and 1000hp + and no-one would recommend anything but a spool shocked we have little room to turn round where we live so a spool was a no tsk Couldn't be happier really, car goes straight and will carry the wheels 100ft+ on most passes up
Re: Spool, truetrac, clutch sure grip or other for street/strip? [Re: Tig] #2790254
06/28/20 11:54 AM
06/28/20 11:54 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Spool in my car was in there when I bought it 30 years ago. Street driven over 1500 miles a season and an average of 50 passes per season.As of now the car has been 9.3 @ 147 ,,,,,,,,,3700 lbs.
OH,,,,,,,and BLACK LINES MATTER for those with Carownersvirus whistling
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Spool, truetrac, clutch sure grip or other for street/strip? [Re: hemi-itis] #2790305
06/28/20 01:21 PM
06/28/20 01:21 PM
moparx Offline
moparx  Offline
nice lines -itis ! up up
i did that one time, and my buddy gathered up all the smoking dust particles and rolled them into a bigger than golf ball size ball of rubber. i still have that thing somewhere........
beer
Re: Spool, truetrac, clutch sure grip or other for street/strip? [Re: moparx] #2790321
06/28/20 02:06 PM
06/28/20 02:06 PM
USA
hudsonhornet7x Offline
USA
This thread has been enlightening. I have always read to stay away from a spool if the car is street driven. I am seeing now that may not be the case. How about in a light rain, does a spool make the car step out in a turn?
Re: Spool, truetrac, clutch sure grip or other for street/strip? [Re: hudsonhornet7x] #2790328
06/28/20 02:14 PM
06/28/20 02:14 PM
Hell yes. Requires pretty careful application of the throttle in any turn on a slick surface! Roundabouts get really interesting.
Re: Spool, truetrac, clutch sure grip or other for street/strip? [Re: hudsonhornet7x] #2790376
06/28/20 03:59 PM
06/28/20 03:59 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
I do my best NOT to get caught in the rain. My tires have no tread! I have a couple of times when it sprinkled and just had to drive slowly and carefully.
'63 Dodge 330
11.19 @ 121 mph
