oil pressure FIXED
#278865
04/05/09 10:16 PM
04/05/09 10:16 PM
Posts: 48 louisiana
71440dart
louisiana
hey guys, hoping someone here can help me get headed in the right direction. i got a 74 duster i traded a buddy for, has a new 408 stroker that i put in, problem is, it didnt come with oil pressure. when priming it i can feel the pump build up resistance (drill starts to bog and almost rip my arm off) nothing shows on the gauge or when i took the gauge off nothing comes out the hole. im baffled, i checked the plug behind the oil filter its there and the one in front the dist, its also there, and the oil filter is full of oil leading me to believe it pumps oil. is it possible the hole could be stopped up with something? thanks in advance for any help
P.S. love the board its great!!
Re: oil pressure
[Re: dOc !]
#278868
04/06/09 09:29 AM
04/06/09 09:29 AM
Posts: 48 louisiana
71440dart
louisiana
i actually started it and ran it for 15-20 seconds.
71 dodge dart race car,440/727 best so far: 11.23 @119
74 plymoth duster, 408SB/727
Re: oil pressure
[Re: buildanother]
#278871
04/06/09 11:21 AM
04/06/09 11:21 AM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Sounds like somebody installed a plug where it should not go. If I remember correctly, the small block galley routing, that the cam bearings won't keep oil from getting to oil pres-gauge block location on rear of block.
This is true. Oil should still get to the gauge or sender. ![](/ubbthreads/images/graemlins/thumbs.gif)
Re: oil pressure
[Re: MoparforLife]
#278872
04/06/09 11:36 AM
04/06/09 11:36 AM
Posts: 7,506 Az
Crizila
Az
Gitten oil to the valve train?
Fastest 300
Re: oil pressure
[Re: 71440dart]
#278874
04/06/09 03:28 PM
04/06/09 03:28 PM
MoparforLife
Upper Midwest
well in that caase you have pressure. Electric gauge??? Make sure wire is hooked up. Mechanical gauge check for kink in line.
Clean it, if it's Dirty. Oil it, if it Squeaks.
But: Don't fix it, if it Works!
Re: oil pressure
[Re: stumpy]
#278877
04/09/09 11:28 PM
04/09/09 11:28 PM
Posts: 48 louisiana
71440dart
louisiana
Thanks for all the suggestions, i have not checked it out due to hurting my back but will let you know whats up when i find out, Thanks again!!!
Re: oil pressure
[Re: 71440dart]
#278878
04/10/09 12:17 AM
04/10/09 12:17 AM
RapidRobert
the mini plug that is supposed to be driven up far enough to where it is between the 2 horizontle passages to/from the filter to divert oil out & back may have gotten driven too far up(past the top horizontle passage)closer to the sending unit & blocking the sending unit passage. Grab that coat hanger & check your depth. If so the good news is the bearings/valvetrain still got fed. Bad news is the oil isn't being filtered & though you only drove it for 20 seconds, how long did he drive it that way. EDIT if so drop the pan & the rear main cap & take off the sending unit & with a stiff rod drive the plug out the bottom & drive in a new one. there's a recess that generally stops the plug at the right place(in between the 2 horizontle passages)so it might not be that & all this info is for naught but holler when you find out what it was.
Re: oil pressure
[Re: RapidRobert]
#278879
04/10/09 10:09 AM
04/10/09 10:09 AM
Posts: 7,506 Az
Crizila
Az
The proper depth measurement for that plug ( PT# 3462871) is 2 1/4" - measured from the rear main block surface to the inside of the cup on the plug ( it is driven in from the main cap surface on the block with the proper size punch that fits inside the cup of the plug.
Fastest 300
Re: oil pressure
[Re: Crizila]
#278880
04/10/09 11:53 AM
04/10/09 11:53 AM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
My money's on that #5 main plug... If they used the wrong size it might just be far enough up to block the pressure tap...
Re: oil pressure
[Re: moper]
#278881
04/10/09 08:31 PM
04/10/09 08:31 PM
Posts: 48 louisiana
71440dart
louisiana
ok, this sounds more like what is going on since i can see it oiling the rockers and it fills the oil filter with oil. bad news is its got a moroso deep pan so its gotta come back out, oh well, thats hot rodding. ![](/ubbthreads/images/graemlins/2231195-dggif.gif) Thanks Again Guys!!
Re: oil pressure
[Re: 71440dart]
#278882
04/18/09 11:12 PM
04/18/09 11:12 PM
Posts: 48 louisiana
71440dart
louisiana
i decided id measure from the top with a hanger and compare to a known good engine, 7 3/4 inch from the top, on both, when i pulled the hanger out it had crud on it, turns out it was actually plugged, guess i didnt consider this since it was a brand new rebuild, ![](/ubbthreads/images/graemlins/hammer.gif) Thanks again guys
Re: oil pressure
[Re: 71440dart]
#278883
04/19/09 12:55 AM
04/19/09 12:55 AM
RapidRobert
Thank you for taking the time to post what the problem turned out to be
