Re: LADDERS BARS
[Re: A/MP]
#2788384
06/23/20 09:51 AM
06/23/20 09:51 AM
Posts: 4,690 On the parachute mount
n20mstr
Ladder bars, that's probably the best drag race suspension out there. Move them up to hit tire harder, down for less hit and more lift at the front of the car (wheelies)
New rod ends and make sure they have safety straps up front. Put the lightest spring in the rear, adjust shocks, Then go blow up that 8 3/4...LOL
....BAD A$$ STREET CAR.....
Re: LADDERS BARS
[Re: A/MP]
#2788389
06/23/20 09:54 AM
06/23/20 09:54 AM
Posts: 20,195 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Lol yaaa it will handle it. Not sure the horsepower in my black Duster but it’s gone 9.42 using ladderbar suspension and 1.25 sixty foot times. When and if I ever get my green Duster Out it with be powered by a 500 plus cubic inch 440-1 headed engine on ladderbar suspension and will be running 8’s in the quarter mile
Re: LADDERS BARS
[Re: pittsburghracer]
#2788681
06/24/20 12:07 AM
06/24/20 12:07 AM
Posts: 10,013 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Ladderbars need good double adjustable shocks, and with a 2.74 low that will agravate the issue. I would consider a 3.91 gear to get the SLR. Down to 10.7. You could also go to a 2.45 low and a 4.10 gear which is a SLR OF 10.0. A loose converter to make it consistant may also help the 8 3/4 live a while.
