Re: AAR vs. T/A Hood Springs
[Re: Chi_Town_Runner]
#53935
08/01/08 08:00 PM
08/01/08 08:00 PM
Posts: 721 Seminole County FL to Plymouth...
Barry70GTX
The pressure is greatest when the hood is "CLOSED"
Frank, If it has all that pressure on it, why doesn't the hood pop open when you pull the pins? It takes a couple of pounds to lift the hood off of the stops before the springs take over.
NMCA NSS 67 Coronet
[Re: Barry70GTX]
#53936
08/01/08 08:27 PM
08/01/08 08:27 PM
Posts: 881 Ohio
B5TA
Ohio
You have to understand that the hood is a "certain " length. now you have to relize where the pivot point of the hinges are. So based on that distance from the hinge to the front of the hood is weight and leverage. So based apond that , length weight and distance to the hinge pivot is the reason why you DO GET THE WARPAGE ! from the force of the spring trying to raise the hood, but it can't because the hood pins are holding it down. Thats why I say leave the stupid springs off! Kev
[Re: Barry70GTX]
#53938
08/02/08 09:17 AM
08/02/08 09:17 AM
Posts: 881 Ohio
B5TA
Ohio
Really!!!! You pull your hood pins and the hood flies up?
Sorry, my bad! I quess I didn't write it like I was trying to say it, so you would understand what I meant. No the hood DOES NOT FLY OPEN ! But yes when the hood is CLOSED those springs are applying upward (constant) pressure on the hood between the hinge and where it is held down at the pins. Ok you guys do what YOU want concerning the use of those springs on your cars , but aleast you know what MY opinion is of them. The hood on my T/A was screwed up because of those springs back in 1972 and to this day is still messed up ! Good Luck To All! Kev
[Re: cataclysm80]
#53941
05/24/12 02:31 PM
05/24/12 02:31 PM
Posts: 247 I DA HOE
3406pac
I DA HOE
Anyone know if this problem has been fixed? I just purchased a set of Year One AAR springs and after rereading this thread, I think I may just return them and make a steel bar to hold the hinge open as described. And return the overpriced springs, as I know they were half that not long ago. Thanks
AAR cuda
71 rag challenger
[Re: cataclysm80]
#2231443
01/10/17 06:38 AM
01/10/17 06:38 AM
Posts: 4,165 Florida
cataclysm80
Time for an update. I saw a few places outside of Moparts where people were still having trouble figuring out what hood springs to use on the Mopar Trans Am cars. I looked at Year One again, and they STILL have their springs mislabeled. That's at least 15 years of misleading people. Vans Auto seems to have their springs labeled correctly, which is nice. Finally a little progress. Hopefully other places will start labeling their parts correctly in the future. This picture should make it easier for everyone to know which spring is for which car. Tav
[Re: cataclysm80]
#2231445
01/10/17 07:17 AM
01/10/17 07:17 AM
Posts: 91 Alaska, USA
Jalaska907
Alaska, USA
I could be mistaken but I was under the assumption that the TA hood springs were lighter tension than the steel hoods. Glass hoods where lighter than steel i thought.
Justin Baldwin Kenai, AK
[Re: 6bblgt]
#2252802
02/13/17 03:40 AM
02/13/17 03:40 AM
cataclysm80
these came with the single 4bbl AAR hood assembly I purchased last year Thanks for the pic Dan! A 4 barrel AAR hood assembly? Is that from one of the factory sponsored race cars? That sounds like an interesting story.
[Re: cataclysm80]
#2785934
06/16/20 09:13 AM
06/16/20 09:13 AM
Posts: 662 Virginia
varunner
Virginia
Has anyone bought a T/A spring lately ? I bought a "T/A"spring a few years ago and now know why my hood doesn't stay all the way up. I went to Van's website, it shows one, but no description. His ebay store doesn't list one, it does list a AAR one. I messaged him, hadn't heard back yet. Also, the spring I have definitely isn't an AAR spring, not sure what I have, but for sure it is either too long or not enough tension. Not worried about hood bowing.
update: just heard from Van's, he doesn't have any T/A springs.......
[Re: varunner]
#2785973
06/16/20 11:09 AM
06/16/20 11:09 AM
Posts: 2,956 GA
roadrunninMark
GA
disregard, wrong springs again...
