Who makes good single stage urethane? #2787699
06/21/20 10:57 AM
06/21/20 10:57 AM
Columbus, GA
Michael Ecks Offline OP
Columbus, GA
My car was painted with Nason years ago back when it was a Dupont product. In painting these quarter scoops with the new Nason I realized how bad my old paint is and plan on shooting the whole car this winter. I also realized how poor the coverage is with the current Nason at least and how thin it is, it really pulls away from edges. I was even having a hard time telling if I was actually laying any down at some points and ended up with what I think is reducer pop across the parts. What I do like about the Nason is how (aside from popped areas) flat and glossy it comes out. Since this isn't a show car, I would probably just wax right over this stuff.
If anyone has other recommendations that cover better and dry to gloss I would love to hear it.
"The happiness of your life depends upon the quality of
your thoughts" ~ Roman Emperor Marcus Aurelius
Re: Who makes good single stage urethane? [Re: Michael Ecks] #2787707
06/21/20 11:11 AM
06/21/20 11:11 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
DuPont split off the auto paint line a while back, now called Axalta. Nason is still under that umbrella as the "economy/budget" product.
Top of the range is Standox, which has been my favorite refinish product for a long time.
I have several cars with Standox on them: good high-solids product, wide library, lays out nicely, lives forever.
But those vehicles are BC/CC.
Bought some Nason single-stage a few months back, color was off but I didn't use my usual guy.
Some colors are pretty transparent: the Jeep grey is one of those. But that was BC/CC.
Re: Who makes good single stage urethane? [Re: topside] #2787726
06/21/20 11:52 AM
06/21/20 11:52 AM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
i am a PPG certified painter, been certified for over 30 years.
it's not rally the " PAINT" that's the problem. single stage urethane paint is basically all the same product made by different manufacturers with minor variations between them.
the problem is the budget part of the paint. to get the budget part the manufactures reduce the type of formulas and tints. one reason might be why it doesn't cover is because the formula is a converted from BC CC to SS paint. to do this they mix up the BC CC formula and then add significant single stage clear binders to make single stage paint. now the paint is well over 50% clear tints and binders.
i would suggest calling the paint store and check if it's a straight up SS formula and not a converted one. to get a straight SS formula you might have to use a premium product line and not the budget line. the problem with this is they don't freely give out this information to just anybody, you need to be a regular buyer of their products who spends $$$ often.
this is also a problem the other way from SS to BC CC formulas.
also paint manufacturers have cut back on older car formulas to save $$$ so straight SS formulas really aren't in demand and used on current model cars anymore. with stricter VOC laws some tints have been discontinued or modified to comply with the regulations. so even with a correct SS formula the tints aren't what they used to be and coverage suffers.
perception is 90% of reality
Re: Who makes good single stage urethane? [Re: Mr T2U] #2787948
06/22/20 12:43 AM
06/22/20 12:43 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Whatever they call DuPont Imron now should give you the results you want, assuming it hasn't been reformulated into something unrecognizable from when I shot it in the 80's.
I'm a rank amateur or worse and it made me look like I knew what I was doing.
Kevin
Re: Who makes good single stage urethane? [Re: Twostick] #2787989
06/22/20 08:58 AM
06/22/20 08:58 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I don't paint often but when I do I use OMNI
Re: Who makes good single stage urethane? [Re: Michael Ecks] #2788068
06/22/20 12:40 PM
06/22/20 12:40 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
Before applying your first coat of paint, go around and cover any sharp edges and body work/primer of a different color with a fog coat . Don't try to spray it on wet right out of the gate. May need to do that twice in order to cover with some paints. Once you have that down and give it a chance to tack it should solve the problem you are having.
Re: Who makes good single stage urethane? [Re: mgoblue9798] #2788380
06/23/20 09:47 AM
06/23/20 09:47 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
That’s a great idea, in fact I’ve been thinking of doing the same only using base coat silver on the edges-seams-channels. Then paint with the single stage A1, thanks for the tip
