Small block Molnar 4.125 crankshaft #2788225
06/22/20 07:58 PM
06/22/20 07:58 PM
east coast
Otherlane Offline OP
east coast
Are their anyone using the Molnar 4.125 small stroker crankshaft with the 2.00 rod journal? If so what length rods are you using? I’m looking to use a 6.300 but I can only find a 6.200 scat rods. Can some point be in the right direction? Thanks
Re: Small block Molnar 4.125 crankshaft [Re: Otherlane] #2788252
06/22/20 08:57 PM
06/22/20 08:57 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Think compstar makes a 6.250 with that rod journal size
I ran a 6.300 compstar on a 4 inch stroker but not 2.000 size
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Small block Molnar 4.125 crankshaft [Re: B3422W5] #2788272
06/22/20 09:55 PM
06/22/20 09:55 PM
east coast
east coast
Will looking into compstar. Thanks
Re: Small block Molnar 4.125 crankshaft [Re: Otherlane] #2788351
06/23/20 08:25 AM
06/23/20 08:25 AM
W. Pa
U
usp4u Offline
usp4u  Offline
U
W. Pa
Pretty sure Oliver has a 6.300/ 2.000 rod
I'm about to order that same crank but going to use a 6.200
Re: Small block Molnar 4.125 crankshaft [Re: usp4u] #2788359
06/23/20 08:55 AM
06/23/20 08:55 AM
east coast
east coast
What brand are you going to use do you have a part #? Looks like the 6.200 will be my choice
Re: Small block Molnar 4.125 crankshaft [Re: Otherlane] #2788390
06/23/20 09:59 AM
06/23/20 09:59 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I'm running a BPE 4.125" crank with Compstar 6.200 rods.
Re: Small block Molnar 4.125 crankshaft [Re: justinp61] #2788400
06/23/20 10:27 AM
06/23/20 10:27 AM
east coast
east coast
Do you have a part number or link..i want to make sure I order the right rod the first time
Re: Small block Molnar 4.125 crankshaft [Re: Otherlane] #2788404
06/23/20 10:34 AM
06/23/20 10:34 AM
W. Pa
U
usp4u Offline
usp4u  Offline
U
W. Pa
probably Carrillo
Re: Small block Molnar 4.125 crankshaft [Re: Otherlane] #2788467
06/23/20 01:40 PM
06/23/20 01:40 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I think the box is still in the shop, I'll check shortly. The rods have are for 2.00" journal and .927" pins.
Re: Small block Molnar 4.125 crankshaft [Re: Otherlane] #2788523
06/23/20 04:37 PM
06/23/20 04:37 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Couldn't find the box.
https://www.cnc-motorsports.com/compstar-csa6200cs2a2ah-h-beam-connecting-rods-41180.html
Re: Small block Molnar 4.125 crankshaft [Re: justinp61] #2788563
06/23/20 06:20 PM
06/23/20 06:20 PM
east coast
east coast
Thanks for your time
Re: Small block Molnar 4.125 crankshaft [Re: Otherlane] #2788568
06/23/20 06:33 PM
06/23/20 06:33 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
