Finally getting a concrete workshop floor
#2788201
06/22/20 06:34 PM
06/22/20 06:34 PM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
For 20 years I've been waiting for all the planets to align and allow me to put a concrete floor in my barn... 6" thick, 1/2" rebar on 18" centers, 15 mil vapor barrier. I want to be able to drive any machine inside that will fit through the door! The pour for the 1st stage starts bright & early tomorrow morning It would have been a lot simpler to make the slab before the barn. Kind of like putting your underwear on after your pants. But the building was already up when I bought this place... and I have so much junk, and no place to store it, that it was simplest to do the center first. A new slab and 40x60 shop just isn't in the budget and I have waited long enough. My four-post lift has been in the crate for several years now. You can see it off to the left side. Next step is to move all the junk onto the slab once it's cured, then do the same prep on the full-length narrow strip and the other square section.
Re: Finally getting a concrete workshop floor
[Re: DrCharles]
#2788219
06/22/20 07:49 PM
06/22/20 07:49 PM
Posts: 15,299 Omaha Ne
TJP
Omaha Ne
[Re: DrCharles]
#2788478
06/23/20 01:57 PM
06/23/20 01:57 PM
Posts: 25,747 Rio Linda, CA
John_Kunkel
Rio Linda, CA
... 6" thick, 1/2" rebar on 18" centers, 15 mil vapor barrier. Good for you, I see too many people opting for a 4" (3 5/8") slab to save a couple of bucks in material then later regretting it.
[Re: DrCharles]
#2788562
06/23/20 06:18 PM
06/23/20 06:18 PM
Posts: 43,118 Bend,OR USA
Cab_Burge
[Re: DrCharles]
#2788771
06/24/20 11:22 AM
06/24/20 11:22 AM
Posts: 17,840 S.E. Michigan
ZIPPY
S.E. Michigan
Looking good, Doc. Garage journal is probably your best resource for floor coating research.
Rich H.
Esse Quam Videri
[Re: DrCharles]
#2788870
06/24/20 03:50 PM
06/24/20 03:50 PM
Posts: 91 Calgary, AB
64Bel
Calgary, AB
Here's a youtuber I follow that applied that to his existing shop floor recently. https://www.youtube.com/watch?v=75NrKtnqjHAThis is the first of 3 episodes. The first vid is mostly prep work but does start applying the product starting around the last 4 minutes of the vid. Good luck with the project!
[Re: DrCharles]
#2789058
06/25/20 01:13 AM
06/25/20 01:13 AM
Posts: 1,908 Nebraska
4406bbl
Nebraska
I did one of mine 14 years ago with plain rustoleum epoxy shield, it has been flawless. I waited 28 days, etched with muratic acid, and rolled it on. I am sure any brand is good but have had friends buy the high dollar cool guy coatings, and super clearcoats and they have problems with hot tires sticking to it. I will warn you that my paint will burn from weld slag, will come off if you beat on it with a hammer, will lift if you put lacquer thinner on it overnight, but that should be obvious. I have another shop with plain power honed super smooth concrete and I like it too, it has stains but as long as you wipe stuff up it is no problem either. I did not put plastic under that slab, 21 and did not know any better, so no faith the paint would stick. My painted floor was power honed, but not as smooth as my non painted. If yours is super smooth have someone shotblast it. The paint is slick when wet, I put rustoleum silica in at 1/2 the recommended amount for a little grip. If you overdo the silica it becomes a [censored] to clean. I think my next floor will be medium honed and concrete stained that brown rust color. .
[Re: DrCharles]
#2789227
06/25/20 06:23 PM
06/25/20 06:23 PM
Posts: 30,994 Oregon
AndyF
Looking good, Doc. Garage journal is probably your best resource for floor coating research. I thought you were talking about a magazine at first... but that would not be anywhere near the oddest Anyhow I've been browsing that forum and it looks like Armorpoxy would be a better choice than anything from a box store. Their"Job on a Pallet" with everything needed is $1500, but Garage Journal forum members get a 15% discount. Guess the price of the man-cave just went up a bit more If you're going to be driving equipment in there and doing heavy work I wouldn't spend $1500 on coating. Have the concrete polished and then just put a coat of wax on it. You'll need to redo the wax every other year or so but it will hold up pretty well and it is easy to sweep up.
[Re: DrCharles]
#2789263
06/25/20 09:24 PM
06/25/20 09:24 PM
AndyF
A polished floor with wax on it will clean up pretty easily. If the concrete isn't polished then it will stain very quickly. When I worked at Xerox we had our machine shop areas polished and waxed. It was the best floor system that we ever came up with. This was in a machine shop where it was common to spill lubricant and other chemicals. Having the floors polished was the key. Grind and seal is a little less money than polishing. Call a local contractor and get some quotes.
[Re: AndyF]
#2789378
06/26/20 10:05 AM
06/26/20 10:05 AM
ZIPPY
S.E. Michigan
Concrete densifier is well worth a look, and will noticeably help the durability of the slab + will help reduce dust produced by the slab.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2789496
06/26/20 02:04 PM
06/26/20 02:04 PM
Posts: 2,673 Northern MN
1E2C
Northern MN
Concrete densifier is well worth a look, and will noticeably help the durability of the slab + will help reduce dust produced by the slab. Never heard of this stuff before, can it be used on cured concrete?
[Re: 1E2C]
#2789860
06/27/20 01:18 PM
06/27/20 01:18 PM
ZIPPY
S.E. Michigan
There are probably different types out there, but the type I used is applied to a cured slab. These are all good. https://www.legacyindustrial.net/products/densifiers/It's used in alot of different ways. Sometimes applied before the slab is put to to work. Other times between stages of grinding and polishing. It's well worth it, even if you change your mind and apply a coating later....but it prevents spills of all kinds from soaking in. If you do a coating later on....and the coating ever fails you won't have dust and so on. If the slab has to be ground first before applying the coating, the densifier will give a nicer substrate. I couldn't think of a reason to not use densifier, other than a slight expense. It's super easy to apply.
Rich H.
Esse Quam Videri
