max wedge/68-70 HP ex manifold width difference #2788144
06/22/20 04:07 PM
06/22/20 04:07 PM
RapidRobert Offline OP
After reading the 440/A body thread further down & there being only 1/8" from his headers to the fender I am wondering if a future planned swap (440/A body/max wedge ex manifolds) will be a no go. Thank you for your time.
Re: max wedge/68-70 HP ex manifold width difference [Re: RapidRobert] #2788148
06/22/20 04:27 PM
06/22/20 04:27 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Maxie exhaust manifolds stick out quite a bit further than HPs do.
Maybe an inch per side, going by memory.
I had an RB with full Maxie exhaust on my '63 Savoy, and they were kinda tight on the right side even in a B-body.
Re: max wedge/68-70 HP ex manifold width difference [Re: topside] #2788161
06/22/20 04:55 PM
06/22/20 04:55 PM
Keizer, Oregon U.S.A.
E
elmor353 Offline
elmor353  Offline
E
Seeing how tight my clearance was with 68 HP manifolds, I can't even imagine trying to fit max wedge manifolds in there.
Re: max wedge/68-70 HP ex manifold width difference [Re: elmor353] #2788233
06/22/20 08:16 PM
06/22/20 08:16 PM
alright it sounds like a no go. thanks guys up
Re: max wedge/68-70 HP ex manifold width difference [Re: RapidRobert] #2788292
06/22/20 10:59 PM
06/22/20 10:59 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
The old Max Wedges were mounted further forward than the later stuff. Gonna take some work in an A-body. hammer
Re: max wedge/68-70 HP ex manifold width difference [Re: bobby66] #2788371
06/23/20 09:27 AM
06/23/20 09:27 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
As cool as the max wedge stock headers are they are very heavy and like having two furnaces under your hood.
A good set of long tube headers would be a better choice in my opinion on anything but perhaps cars that came with max wedges.
Re: max wedge/68-70 HP ex manifold width difference [Re: RapidRobert] #2788375
06/23/20 09:41 AM
06/23/20 09:41 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Number 1 thing to do is start with a 400, no 440.
Re: max wedge/68-70 HP ex manifold width difference [Re: 340Cuda] #2788376
06/23/20 09:43 AM
06/23/20 09:43 AM
yeah they for sure are heavy. I have some good money invested in em so I'd like to put em to good use.
Re: max wedge/68-70 HP ex manifold width difference [Re: RapidRobert] #2788456
06/23/20 01:19 PM
06/23/20 01:19 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Yeah, they weigh a ton.
Something I forgot to mention is that they're also longer front-to-back than HPs.
So the right side doesn't fit later Bs with their engines set back further than the early cars.
On my '63, I had to add a heat baffle for its dual master cylinder.
Found that out on its maiden half-four drive when the brake pedal got real mushy...
Re: max wedge/68-70 HP ex manifold width difference [Re: topside] #2788659
06/23/20 09:55 PM
06/23/20 09:55 PM
I didn't do my homework first & it bit me here frown
