Steel or wood garage?
#2788037
06/22/20 11:17 AM
06/22/20 11:17 AM
Posts: 834 In the Middle
roadntrack
In the Middle
Trying to decide whether to go steel or wood walls
Remember when cars were FUN?
Re: Steel or wood garage?
[Re: roadntrack]
#2788048
06/22/20 12:00 PM
06/22/20 12:00 PM
Posts: 35,047 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
I built a wood framed garage , steel has some good points too .. just a matter of preference ..don't think the cost is much different
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: 65pacecar]
#2788153
06/22/20 04:37 PM
06/22/20 04:37 PM
Posts: 16,186 Mesa, Arizona
dart4forte
Mesa, Arizona
Steel much cooler however more expensive to heat
Steel much easier to get a permit, less fire codes to meet
Steel goes up faster than a stick building
Easier todo finish work in a wood building
Abe Lincoln
[Re: poorboy]
#2788280
06/22/20 10:19 PM
06/22/20 10:19 PM
Posts: 31,200 Oregon
AndyF
Lots of variables. What part of the country the garage will be built at could make a difference. How high the side walls will be will also make a difference. Insulation and interior wall covering also matter, as might local building codes. The appearance of surrounding buildings may play into it as well, might not want to have the only garage in the area built like yours. Gene I agree with those points. Also need to consider how large the building is going to be. Wood works just fine for a small structure, you'll need steel if it is going to be very large or if you want to support weight. I had to go steel on my shop since I wanted a bridge crane. No way are you going to hang a bridge crane from any normal wood structure. Wood is easier to work with for a backyard carpenter so if a person is going to finish it themselves then wood might be a good choice.
[Re: John_Kunkel]
#2788491
06/23/20 02:43 PM
06/23/20 02:43 PM
roadntrack
In the Middle
Mine will just be a 12x28 Main concern is condensation with steel vs wood
[Re: roadntrack]
#2788492
06/23/20 02:49 PM
06/23/20 02:49 PM
Posts: 1,551 USA
hudsonhornet7x
USA
Mine will just be a 12x28 Main concern is condensation with steel vs wood I have a 40x50 Steel building in Northwest Pennsylvania and condensation has not been an issue for me.
[Re: RusTy/SE]
#2788841
06/24/20 02:40 PM
06/24/20 02:40 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Well I am contemplating a 50x80, going big enough to put everything out of the sun and snow...pole barn was my first choice up until I realized that I have a high water table at 3' below grade, so I will just do a steel building on pilings
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: roadntrack]
#2789202
06/25/20 05:05 PM
06/25/20 05:05 PM
Posts: 2,136 Byron, NY
W.I.N. Racing
Byron, NY
Ass all have said depends.. I went with wood frame for multiple reasons; Matches the character of my house Type of tools/equipment required to construct familiarity of construction process cost to finish interior insulation cost potential future conversion to a residence - never know I may get tired of playing with cars All vinyl /Aluminum exterior
that was my decision process anyways...
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
