Steel or wood garage? #2788037
06/22/20 11:17 AM
06/22/20 11:17 AM
In the Middle
roadntrack Offline OP
In the Middle
Trying to decide whether to go steel or wood walls
Remember when cars were FUN?
Re: Steel or wood garage? [Re: roadntrack] #2788048
06/22/20 12:00 PM
06/22/20 12:00 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
I built a wood framed garage , steel has some good points too .. just a matter of preference ..don't think the cost is much different
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Steel or wood garage? [Re: roadntrack] #2788049
06/22/20 12:00 PM
06/22/20 12:00 PM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
Lots of variables. What part of the country the garage will be built at could make a difference. How high the side walls will be will also make a difference. Insulation and interior wall covering also matter, as might local building codes. The appearance of surrounding buildings may play into it as well, might not want to have the only garage in the area built like yours. Gene
Re: Steel or wood garage? [Re: roadntrack] #2788084
06/22/20 01:24 PM
06/22/20 01:24 PM
central il.
second 70 Offline
second 70  Offline
central il.
Check out the price of material it should make the decision easier.
Re: Steel or wood garage? [Re: second 70] #2788105
06/22/20 02:22 PM
06/22/20 02:22 PM
KY
65pacecar Online happy
65pacecar  Online Happy
KY
I have both and advantages to each one. Steel is less upkeep, quick to install and assemble and easy to expand depending on the style and manufacturer. The steel building seem to take more insulation than the wood structures to keep warm/cool and prevent sweating. I like both and have a tendency to over insulate either way, also make sure you use a good moisture barrier under the concrete.
Re: Steel or wood garage? [Re: 65pacecar] #2788153
06/22/20 04:37 PM
06/22/20 04:37 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Steel much cooler however more expensive to heat
Steel much easier to get a permit, less fire codes to meet
Steel goes up faster than a stick building
Easier todo finish work in a wood building
Abe Lincoln
Re: Steel or wood garage? [Re: roadntrack] #2788207
06/22/20 07:06 PM
06/22/20 07:06 PM
AndyF Offline
AndyF  Offline
Really depends on how you want to finish it out. I went with steel because I needed the strength for the long span. The contractor I used had some different options for finishing the inside. They used a wrapped insulation and then installed white steel panels for the inner walls. The electrical was then run in conduit on top of the white panels. They also installed windows although you might not want windows in your shop depending on the neighborhood.
Re: Steel or wood garage? [Re: AndyF] #2788267
06/22/20 09:49 PM
06/22/20 09:49 PM
KY USA
mopargem Offline
mopargem  Offline
KY USA
I went with steel exterior, no rot and won’t have to paint in my lifetime.
Re: Steel or wood garage? [Re: poorboy] #2788280
06/22/20 10:19 PM
06/22/20 10:19 PM
AndyF Offline
AndyF  Offline
I agree with those points. Also need to consider how large the building is going to be. Wood works just fine for a small structure, you'll need steel if it is going to be very large or if you want to support weight. I had to go steel on my shop since I wanted a bridge crane. No way are you going to hang a bridge crane from any normal wood structure. Wood is easier to work with for a backyard carpenter so if a person is going to finish it themselves then wood might be a good choice.
Re: Steel or wood garage? [Re: roadntrack] #2788472
06/23/20 01:48 PM
06/23/20 01:48 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
When I was contemplating steel/stick for my 4-car garage a friend quipped "if you're worried about security, all you need is a can opener to get into a steel building". grin
Re: Steel or wood garage? [Re: John_Kunkel] #2788491
06/23/20 02:43 PM
06/23/20 02:43 PM
In the Middle
In the Middle
Mine will just be a 12x28 Main concern is condensation with steel vs wood
Re: Steel or wood garage? [Re: roadntrack] #2788492
06/23/20 02:49 PM
06/23/20 02:49 PM
USA
hudsonhornet7x Offline
USA
I have a 40x50 Steel building in Northwest Pennsylvania and condensation has not been an issue for me.
Re: Steel or wood garage? [Re: hudsonhornet7x] #2788515
06/23/20 04:19 PM
06/23/20 04:19 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Steel stud guys are more money than guys who do wood framing where I'm at. It's two different groups with two different sets of tools.
Re: Steel or wood garage? [Re: John_Kunkel] #2788586
06/23/20 07:09 PM
06/23/20 07:09 PM
Oh
P
parksr5 Offline
parksr5  Offline
P
Oh
This happened to a friend of mine in a nice area. They cut a hole in the side of the building to get in, opened one of the barn doors and cleared him out in one night. He lost 90k worth of stuff.
Re: Steel or wood garage? [Re: parksr5] #2788643
06/23/20 09:09 PM
06/23/20 09:09 PM
Montgomery, Alabama
RusTy/SE Offline
RusTy/SE  Offline
Montgomery, Alabama
In Central Alabama the heat, humidity and my location on a small lot in a residential neighborhood went into my choice of steel garage.
Re: Steel or wood garage? [Re: RusTy/SE] #2788841
06/24/20 02:40 PM
06/24/20 02:40 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Well I am contemplating a 50x80, going big enough to put everything out of the sun and snow...pole barn was my first choice up until I realized that I have a high water table at 3' below grade, so I will just do a steel building on pilings
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Steel or wood garage? [Re: mopargem] #2789127
06/25/20 11:30 AM
06/25/20 11:30 AM
Bowling Green, KY
cudaboy Offline
cudaboy  Offline
Bowling Green, KY
So did I.
Dennis
Re: Steel or wood garage? [Re: roadntrack] #2789202
06/25/20 05:05 PM
06/25/20 05:05 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Ass all have said depends..
I went with wood frame for multiple reasons;
Matches the character of my house
Type of tools/equipment required to construct
familiarity of construction process
cost to finish interior
insulation cost
potential future conversion to a residence - never know I may get tired of playing with cars
All vinyl /Aluminum exterior
that was my decision process anyways...
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Steel or wood garage? [Re: John_Kunkel] #2789221
06/25/20 06:11 PM
06/25/20 06:11 PM
AndyF Offline
AndyF  Offline
If someone is going to cut their way into a building it is a lot easier to cut wood than steel.
Re: Steel or wood garage? [Re: W.I.N. Racing] #2789222
06/25/20 06:13 PM
06/25/20 06:13 PM
AndyF Offline
AndyF  Offline
That look nice. I see that you used a steel interior in your wood building. That is a good idea in a shop since the steel siding will stand up to more abuse than drywall. It is a little harder to install though.
