Page 2 of 3 1 2 3
Re: Dissapointed with my run with 69 Roadrunner/440 6pk [Re: Dave Watt] #278786
04/06/09 10:58 AM
04/06/09 10:58 AM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
Check this thread https://board.moparts.org/ubbthreads/show...rue#Post2941623 for more details and photos.
Re: Dissapointing Run w/440 6pk [Re: Bob_Coomer] #278787
04/06/09 11:00 AM
04/06/09 11:00 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Non Believers LOL
Not only did they do it, they did it bragging, and as a advertisement Logo.
"In 1968 with the intro of the Plymouth Road runner, Mopars claim to fame was Speed on a budget, designed to run 100 mph in the 1/4 mile and sell for under $3000".
You probably wouldn't believe this same car with a little work, still carrying stock 906 heads, and Factory fuel system wouldn't run no where near 11.20's in the 1/4 either...
Rapid Transit's Believe it or not
a 383 RR w/ 3.55's on bias tires, even tuned to the nines, with a pro driver wouldn't do 14.0's...maybe 14.40@95 maybe.
and it will need a TON of work, meaning stroker, roller cam $$$$$ in head works to run in the 11's. If not I want to hear the combo so I can build one.
Re: Dissapointing Run w/440 6pk [Re: Mr.Yuck] #278788
04/06/09 11:27 AM
04/06/09 11:27 AM
MD
Kevins493 Offline
Kevins493  Offline
MD
Theres a guy on here with a factory stock class (BONE stock) 383 superbee that runs 13.5's. Maybe he'll post on this thread. Its amazing whats possible when you're really good at tuning....
Re: Dissapointing Run w/440 6pk [Re: Mr.Yuck] #278789
04/06/09 11:29 AM
04/06/09 11:29 AM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
What are the other time increments and speeds? It seems slow. How much is the driver tho? When does the acceleration peter out? What rpm are you launching and shifting at? What is the timing curve? To me, 38° may be a little too much timing. What springs are in the outboard carbs?
I know modern performance rebuilt, stock-part 383s that with decent tires and 3.23s will pull 100mph in the 1/4. Factory original or not, they can do it with the stock cam and a good tuner.
Re: Dissapointing Run w/440 6pk [Re: moper] #278790
04/06/09 12:14 PM
04/06/09 12:14 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
depending on gas 38* would be my start but 36* is good too. Yeah I failed to add what is your rpm launch, of course it's probably a little low because of your tires...You might want to roll out then hit it.
Best I could do with a 383 in a 69 Charger w/ 3.23's on radials was 14.10@101 but that was a very stout 509 cammed 383. 3.91's and slicks knocked me down to 13.28 same engine in a 68 dart and 4.56's went 12.18 w/ a terrrrible trans, but that's OT.
Re: Dissapointing Run w/440 6pk [Re: Mr.Yuck] #278791
04/06/09 12:15 PM
04/06/09 12:15 PM
WASHINGTON, PA
11secaarcuda Offline
WASHINGTON, PA
Did you check the throttle linkage?
67 Dart GT 340 4 speed
70 AAR Cuda 408 6 barrel
96 Indy Ram original owner
2011 Hemi Durango
Re: Dissapointing Run w/440 6pk [Re: 11secaarcuda] #278792
04/06/09 12:28 PM
04/06/09 12:28 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Without know other factors its hard to say where the
problem truly is... but you said you have a restricted
fuel system... thats gonna hurt, specially on a 6 pac
and 5/16 line, all HP engines from the factory had 3/8
fuel lines and pick ups. It suprizes me that you had
the best ET when you ran the 2.19 60'
Re: Dissapointing Run w/440 6pk [Re: MR_P_BODY] #278793
04/06/09 12:48 PM
04/06/09 12:48 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I have a 1970 rt charger 440 4 speed when it was bone stock the best I ever got out of it was 14.10's in the mid 90's mph. A lot of practice leaving with the stick netted et. Mr. p is correct factory "muscle" cars left with 3/8 line. My biggest problem in that configuation was the factory fuel filter and pump. The filter had that built in vapor separator. It would lay over in 4th. Replaced the fuel pump with an hp Carter and filter with a regular 3/8's one and plugged the vapor line back to the tank.
Re: Dissapointing Run w/440 6pk [Re: MR_P_BODY] #278794
04/06/09 01:02 PM
04/06/09 01:02 PM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
Hey Blond,
Keep working with it, and it will come around.
We all can agree on one thing! It will be fun
putting passes on it, chasing ET's!
Snap your neck, mega G-force launch, is all I want!
Re: Dissapointing Run w/440 6pk [Re: Kevins493] #278795
04/06/09 01:15 PM
04/06/09 01:15 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Yes , he does have more gear either 3.91's or 4.10's and the car is over 3800 lbs .
My dart at 3600 with driver has gone 14.teens at 99.5mph with a timing chain that was so stretched and the plastic broken off the stock cam gear that I could have pulled it off without removing the gears .
The RR that this thread is about has a huge issue , and it could be the outboards not opening , that car should be in the low 13's .
Re: Dissapointing Run w/440 6pk [Re: Kevins493] #278796
04/06/09 01:34 PM
04/06/09 01:34 PM
hemisurfer Offline
hemisurfer  Offline
That would be my brother Florida_70Bee.
Ran a best of 13.47 the last time we were at Gainesville with a 1970 Super Bee 383 automatic.You would need to ask him about the combo.
I have a 69 RR 6 pack stroker 4 speed dana 410 same issues and almost identical times first time out, look at:
Fuel delivery
Headers
the heads themselves
stroker might be a bit different since it needs more air but the combo is close. The MPH should be over 100 minimum IMO for a six pack car.
Chris
Re: Dissapointing Run w/440 6pk [Re: hemisurfer] #278797
04/06/09 01:50 PM
04/06/09 01:50 PM
Indiana
Cuda_Mike Offline
Cuda_Mike  Offline
Indiana
Actually, the 69.5 A-12 M-code 6 Barrel cars came with 5/16" fuel lines. I always upgrade to 3/8 though.
Re: Dissapointing Run w/440 6pk [Re: Cuda_Mike] #278798
04/06/09 01:57 PM
04/06/09 01:57 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
clamp the springs.....
Mopar Performance
Re: Dissapointing Run w/440 6pk [Re: moparniac] #278799
04/06/09 02:15 PM
04/06/09 02:15 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
the rear pass side spring? I tired that once in a 67 coronet and I din't see any improvement. what's the trick? The car was doing 1.68 60 foot.
Re: Dissapointing Run w/440 6pk [Re: Mr.Yuck] #278800
04/06/09 03:27 PM
04/06/09 03:27 PM
MD
Kevins493 Offline
Kevins493  Offline
MD
Doesnt make it 60' faster unless its spinning. Keeps it from going into wheelhop and it recovers quicker too...
Re: Dissapointed with my run with 69 Roadrunner/440 6pk [Re: BLONDE BARRACUDA] #278801
04/06/09 04:51 PM
04/06/09 04:51 PM
South Carolina, United States
carolinacuda Offline
My old combo in a 74 cuda went 13.15 @ 107mph with a puny 2.09 60ft. I had a stock 440 with a 474 purple cam and torker intake and 3.91's with headers and 750 carb. My fuel system was all stock with a carter hi-po fuel pump. So I think you shld have more in that combo.
Re: Dissapointed with my run with 69 Roadrunner/440 6pk [Re: carolinacuda] #278802
04/06/09 05:56 PM
04/06/09 05:56 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Just for reference: My full weight 67 Satellite with a low compression (2-bbl) 125,000 mile stock bottom end 383 and stock small valve 516 heads has gone 14.00 @ 98.68 MPH. It 60's @ 2.09. It's had the standard street hot rod treatment of headers, intake, Holley 4-bbl, 280*-ish cam, and a set of 3.91's.
Re: Dissapointed with my run with 69 Roadrunner/440 6pk [Re: StealthWedge67] #278803
04/06/09 06:52 PM
04/06/09 06:52 PM
Bakersfield, CA
Jared_Jordan Offline
Bakersfield, CA
I went 13.73 @ 99 mph with a stock low compression 383 rebuild through exhaust manifolds in my Roadrunner a few years ago. 3.91 gears/auto trans w/stock valve body. It did have slicks on but only went 2.03 60 ft. Car weighs 3700 lbs with me in it.
Re: Dissapointed with my run with 69 Roadrunner/440 6pk [Re: BLONDE BARRACUDA] #278804
04/06/09 06:53 PM
04/06/09 06:53 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
Mr. 6Pack Racing Engines - Link
Bob Karakashian… ‘Mr Six Pack’ Article by Terry Cooper
YouTube: Mr. 6Pack 8.09 @ 87.35 1/8th mile track
With your six pack set up I highly recommend giving Bob Karakashian a call.
Bob runs his A12 69 ½ Super Bee in the Pure Stock Muscle Car Drags and turns 12.09 seconds in the quarter @ 114 mph. He does it with the required factory HP exhaust manifolds, stock un-ported 906 heads, a full exhaust system, Carter mechanical fuel pump, and skinny G70-15 redline tires. Even more impressive, Bob’s cam in a 69 ½ Road Runner broke into the high 11s. Now that’s good tuning!
Anyway, Bob is a nice guy and is glad to help.
Check out this moparts.com thread HERE
CompSyn
Re: Dissapointed with my run with 69 Roadrunner/440 6pk [Re: BLONDE BARRACUDA] #278805
04/06/09 08:01 PM
04/06/09 08:01 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
You're way down on power. From where you are now, it is not a fine tuning issue.
1. Make sure you've got fuel, put on a good pump and filter. 5/16" line is not the problem at 95 mph, unless it is damaged.
2. Make sure the outboards are opening and opening soon enough. The outboard throttle plates can stick. You should be able to pull the vacuum line off the center carb and suck on the line and the outboards open. Check kill bleeds, or other possible problems in the vacuum pods.
3. Check the cranking cylinder pressure to see what you have and possibly identify a motor problem.
4. If the mufflers are old, they can fail internally causing a pluggage and rob a bunch of power. I had one muffler fail on a 105 mph car and it lost 4 mph and 0.5 sec in et from one weekend to the next. Took me a few weeks to figure that one out. I can only image what two failed mufflers could do.
For the DA of at least a few Wisconson tracks on Saturday, a decent 440-6 4 speed should have gone at least 105 mph. Your missing 100 hp.
Page 2 of 3 1 2 3
