Allison TranSynd ATF #2787520
06/20/20 06:42 PM
06/20/20 06:42 PM
NW Indiana
P
powertrip Offline OP
P
NW Indiana
Scored a case of this stuff made by Castrol at a garage sale. Supposedly heavy duty full synthetic ATF. Anybody use this in a built 727?
Re: Allison TranSynd ATF [Re: powertrip] #2787547
06/20/20 08:17 PM
06/20/20 08:17 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
I do, no issues in 7 years.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Allison TranSynd ATF [Re: BloFish] #2787554
06/20/20 08:41 PM
06/20/20 08:41 PM
NW Indiana
P
P
NW Indiana
What is your application, and why did you start using it?
Re: Allison TranSynd ATF [Re: powertrip] #2787664
06/21/20 09:00 AM
06/21/20 09:00 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Street/strip 500ci, 727rmvb, 4.56 gears. After assembling the the car I started using tranSynd from the start by a buddy who worked on/with Aliison.
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Allison TranSynd ATF [Re: BloFish] #2787668
06/21/20 09:21 AM
06/21/20 09:21 AM
NW Indiana
P
P
NW Indiana
Thanks for the vote of confidence!
Re: Allison TranSynd ATF [Re: powertrip] #2787680
06/21/20 10:09 AM
06/21/20 10:09 AM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
Ive been told most performance clutch material was developed around gm products so the correct fluid to use in a built transmission is Dexron VI.
Re: Allison TranSynd ATF [Re: Uberpube] #2788666
06/23/20 10:41 PM
06/23/20 10:41 PM
PA
moparacer Offline
moparacer  Offline
PA
It will work but you wont notice much of a difference between it and anything else. I fooled with hydraulic fluid years ago and all it did was make my wallet lighter and my eyes hurt trying to read the dipstick because it was clear.
I just went through my glide that I have raced since oh, 1998 or so.....Has the red clutches in it and I reused them again, because, they still look like new.
Have always ran type F in it.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
