Control arms into k frame
#2787314
06/20/20 05:58 AM
06/20/20 05:58 AM
Posts: 8,844 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
Been a while since took the k frame out and had it blasted and painted. But trying to round up parts to put back into the cuda
Have the bushings out of the lower control arms and need new ones. But is there not a bushing or something that goes between the pin and the k frame its self? What would it be called and where can I buy them? If so. Are the pressed into the k frame? Or justbslip In?
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
Re: Control arms into k frame
[Re: toplescuda]
#2787367
06/20/20 11:24 AM
06/20/20 11:24 AM
Posts: 18,678 Fresno, CA
Jim_Lusk
Fresno, CA
Have the bushings out of the lower control arms and need new ones. But is there not a bushing or something that goes between the pin and the k frame its self? What would it be called and where can I buy them? If so. Are the pressed into the k frame? Or justbslip In? The pin goes into the k-member without a bushing. As you tighten the nut the fit becomes interference, barely. That's why you never tighten up the pin nut until the ride height is set.
[Re: Jim_Lusk]
#2787453
06/20/20 03:59 PM
06/20/20 03:59 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
Thank you. Did not know that... that's good need to know info Bought some bushings.(moog) For control arms. Had to take them back. As 1 went 100%all way in by hand. The other went all way in except last 1/4 inch by hand. The pins don't look to have any real wear or anything....so went and order some from some where else (differant brand also) will have the pins with me. If they don't need pressed in. They can keep them
[Re: Jim_Lusk]
#2787455
06/20/20 04:04 PM
06/20/20 04:04 PM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
