Re: Best master cylinder
[Re: bobs69]
#2787584
06/20/20 10:07 PM
06/20/20 10:07 PM
Posts: 43,269 Bend,OR USA
Cab_Burge
For what type of drag car? How fast is it in MPH at the finish line, how long is the track length and shut down area, and how much does the car weigh?
[Re: Cab_Burge]
#2792231
07/03/20 09:43 AM
07/03/20 09:43 AM
Posts: 144 PA
dixie2bird
PA
For what type of drag car? How fast is it in MPH at the finish line, how long is the track length and shut down area, and how much does the car weigh? I'm going to hijack this post if you don't mind. I have the same question. I blew my master cylinder out racing and I'm looking for something a bit more heavy duty. 72 Cuda 340 95 - 100 miles/hr 1/4 mile; not sure how long the shut down area is. It wasn't very long .. hence hard braking 3,000 lbs (maybe lighter - had no interior in it at the time
1972 Cuda 340 4-speed 2015 Challenger SRT 392 2015 Jeep Wrangler Unlimited Willy's
[Re: dixie2bird]
#2792250
07/03/20 10:29 AM
07/03/20 10:29 AM
Posts: 52,972 Romeo MI
MR_P_BODY
For what type of drag car? How fast is it in MPH at the finish line, how long is the track length and shut down area, and how much does the car weigh? I'm going to hijack this post if you don't mind. I have the same question. I blew my master cylinder out racing and I'm looking for something a bit more heavy duty. 72 Cuda 340 95 - 100 miles/hr 1/4 mile; not sure how long the shut down area is. It wasn't very long .. hence hard braking 3,000 lbs (maybe lighter - had no interior in it at the time Your issue isnt the master.. you need bigger brakes... unless you put a larger dia master on.. which is the wrong thing.. bigger master you have to push the pedal harder to get the same pressure.. a smaller one will apply more pressure with lesser pedal pressure
[Re: MR_P_BODY]
#2792334
07/03/20 01:14 PM
07/03/20 01:14 PM
Cab_Burge
For what type of drag car? How fast is it in MPH at the finish line, how long is the track length and shut down area, and how much does the car weigh? I'm going to hijack this post if you don't mind. I have the same question. I blew my master cylinder out racing and I'm looking for something a bit more heavy duty. 72 Cuda 340 95 - 100 miles/hr 1/4 mile; not sure how long the shut down area is. It wasn't very long .. hence hard braking 3,000 lbs (maybe lighter - had no interior in it at the time Your issue isnt the master.. you need bigger brakes... unless you put a larger dia master on.. which is the wrong thing.. bigger master you have to push the pedal harder to get the same pressure.. a smaller one will apply more pressure with lesser pedal pressure Been there done that before I was aware that the same looking master cylinder could come with two different bore sizes and finding out going to bigger was not the correct way to help stop the race car on a short track I found out later I had switch from a 15/16 to 1 1/8 bore size I had to almost stand on the dang brake peddle to get it to stop My current S/P bracket car has dual Willwood master cylinder with 15/16 bore size, my car has dual calipers on the rear end and stops fine at 150.MPH in the 1/4 mile, not so easy on stopping at 120.MPH in the 1/8 mile at our local track
[Re: moparx]
#2792486
07/03/20 11:46 PM
07/03/20 11:46 PM
Cab_Burge
cab, what size bore rear calipers are you using ? I have no idea, they where on the car when I got it I can't remember if their four pistons or six pistons, I think the rotors are under 12.0 inch diameter. I replace the rears several years ago due to them being heat cracked a bunch so I can try and measure them. They are 11 1/4 O.D. The car is in the trailer at the race track, I think it has the same size four piston calipers on both ends, dual calipers on the rear end. It stops fine so far, hoping to turn it up this year
