Hemi "nail head" valves? #2786809
06/18/20 01:42 PM
06/18/20 01:42 PM
Lake Villa Il
INTMD8 Offline OP
INTMD8  Offline OP
Lake Villa Il
Looking at an old article I see these mentioned by Chuck Lofgren. Would reach out to him but it says shop is permanently closed.
https://www.hotrod.com/articles/mopp-0603-2005-mopar-muscle-engine-challenge-results/
I asked Ferrea about them and they don't know what they are.
Anyone have an idea or just not commonly used/beneficial? Thank you.
Re: Hemi "nail head" valves? [Re: INTMD8] #2786822
06/18/20 02:03 PM
06/18/20 02:03 PM
New York
polyspheric Offline
polyspheric  Offline
New York
IFAIK, this originally referred to the small head diameter valve used in 1953-66 Buick V8 engines.
They may be referring to the head shape, or rather the stem-to-head radius, in which the head fits the stem like a "penny on a stick" or letter "T". This is the opposite of what hemi engines commonly use, the "tulip" valve with a big convex bell instead of a radius.
Boffin Emeritus
Re: Hemi "nail head" valves? [Re: INTMD8] #2786888
06/18/20 04:28 PM
06/18/20 04:28 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I’m sure the blank they’re using for their 5/16” stem BBC valves could be made at the correct Hemi length if one really wanted to try it
Of course, for flow testing the length wouldn’t matter.
Just buy the appropriate BBC valve and see how it works.
I had some old Top Alcohol style Hemi heads here a couple years ago.
Some variation of the castings made by Stage V.
2.400 intake valves iirc........ and a normal looking non-tulip design.
Re: Hemi "nail head" valves? [Re: fast68plymouth] #2786895
06/18/20 05:10 PM
06/18/20 05:10 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Lofgren is still doing business as far as I know.
A buddy was at his shop last week talking transmission with him.
He is difficult to get on the phone , but he is definitely still there.
If you really want to get in touch with him , I will find a good number for you.
Re: Hemi "nail head" valves? [Re: tubtar] #2786916
06/18/20 06:35 PM
06/18/20 06:35 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
I tried a Manley BBC 2.25" intake valve in my MCH ported bracket heads. I lost flow from .100" on up with the BBC valve.
Lift Manley 12850 BBC MP Intake Valve
0.050 34.30 32.63
0.100 64.84 72.37
0.150 95.38 114.62
0.200 133.03 146.00
0.250 167.33 180.72
0.300 203.31 219.20
0.350 238.87 256.02
0.400 277.49 297.30
0.450 311.57 332.25
0.500 347.93 362.21
0.550 369.65 387.22
0.600 384.86 403.09
0.650 397.97 406.98
0.700 399.91 417.61
0.750 406.40 419.97
0.800 411.12 423.20
0.850 412.29 428.24
Floyd Lippencott IV
Re: Hemi "nail head" valves? [Re: mr_340] #2786917
06/18/20 06:39 PM
06/18/20 06:39 PM
So. Burlington, Vt.
So. Burlington, Vt.
Those are some noticeable losses in flow.
It seems as though if it were the hot ticket, you’d hear more about it.
Re: Hemi "nail head" valves? [Re: mr_340] #2786961
06/18/20 09:13 PM
06/18/20 09:13 PM
Lake Villa Il
INTMD8 Offline OP
INTMD8  Offline OP
Lake Villa Il
Great info mr_340
Thanks for the responses guys. Sounds like tulip is the way to go.
Re: Hemi "nail head" valves? [Re: INTMD8] #2787316
06/20/20 07:14 AM
06/20/20 07:14 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
A nail head works great in a millennium hemi head, but not so much in a conventional. The millennium port has enough runner length, and short turn to allow it. Cuts a bunch of weight off the valve too.
Re: Hemi "nail head" valves? [Re: dthemi] #2787599
06/20/20 11:05 PM
06/20/20 11:05 PM
Lake Villa Il
INTMD8 Offline OP
INTMD8  Offline OP
Lake Villa Il
^ appreciate the info
Re: Hemi "nail head" valves? [Re: INTMD8] #2787612
06/21/20 12:04 AM
06/21/20 12:04 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
After Lofgren won the Royal purple Hemi challenge, he parted out the engine and I bought the heads. I put them on my red F.A.S.T. GTX. The intake valves are very flat on the backside. The late Glen Knowlton did all of the head work on them, he was a genius. They flowed around 420ish, but according to Glen the more important thing was the outstanding flow at lower valve lift numbers. The exhaust side flowed 315. I still have those heads laying around here somewhere.
Regarding that contest, according to Chuck the rules were very clear about displacement. When so many of the entries were found to be cheating on the displacement, or else they never read the rules, the organizers just let them all run anyway. Chuck was not happy about that. Then they made up some crap for the article about a misunderstanding of the rules.I'm so glad that Chuck won it because he was about the only one that was legal. You can probably reach him at KTRE. Knowlton's thunderheads racing engines.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Hemi "nail head" valves? [Re: Hemi_Joel] #2787696
06/21/20 10:51 AM
06/21/20 10:51 AM
New York
polyspheric Offline
polyspheric  Offline
New York
The tulip shape masks the port at low lift
Boffin Emeritus
Re: Hemi "nail head" valves? [Re: polyspheric] #2787876
06/21/20 07:38 PM
06/21/20 07:38 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
An asymmetrical valve job goes a long way to help the short radius problem too, and helps every hemi I've ever touched,
Re: Hemi "nail head" valves? [Re: INTMD8] #2788009
06/22/20 09:57 AM
06/22/20 09:57 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Anything that significantly affects low lift flow also affect the best choice of LSA and overlap. Less flow needs more OL, narrower LSA.
If it's faster with more low lift flow, maybe the cam was too small?
Boffin Emeritus
Re: Hemi "nail head" valves? [Re: polyspheric] #2788039
06/22/20 11:25 AM
06/22/20 11:25 AM
Lake Villa Il
INTMD8 Offline OP
INTMD8  Offline OP
Lake Villa Il
Hemi Joel, neat that you own those heads smile
I could see how if it's faster with optimizing low lift flow maybe it just needed more cam. What are we talking when we say low lift? I'm planning on keeping lift low (sub .640) as I'm running stock rockers.
Re: Hemi "nail head" valves? [Re: dthemi] #2788042
06/22/20 11:50 AM
06/22/20 11:50 AM
NW Indiana
P
powertrip Offline
powertrip  Offline
P
NW Indiana
I have started the turn for the short side right under the 45* seat angle in some applications, is this similar to what you do?
