What size pin #2786874
06/18/20 04:00 PM
06/18/20 04:00 PM
Omaha, Nebraska
Scott Carl Offline OP
Omaha, Nebraska
What size pin holds the reluctor in place on a small block distributor? The one that came out just drops in. Slop in the hole. Guessing its the hole itself but I want to mic the pin. This common?
Thanks in advance,
Scott
Re: What size pin [Re: Scott Carl] #2788003
06/22/20 09:45 AM
06/22/20 09:45 AM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Uh, the ones I have seen/worked on . . . were all a roll pin . . . if it seemed "loose", just took a screwdriver and opened the slot up a bit to create enough interference to fit tightly . . . just my 2cents . . .
