68 GTX 440 fuel system? #2786241
06/17/20 08:28 AM
06/17/20 08:28 AM
Columbus, Ohio
Chally426 Offline OP
Columbus, Ohio
What would be correct for this car? 5/16" I'm guessing, also, would there be a return line of any kind?
Re: 68 GTX 440 fuel system? [Re: Chally426] #2786258
06/17/20 09:18 AM
06/17/20 09:18 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
5/16, no return line as I remember...Joe
Re: 68 GTX 440 fuel system? [Re: jlatessa] #2786293
06/17/20 10:45 AM
06/17/20 10:45 AM
N
NITROUSN Online content
NITROUSN  Online Content
N
3/8 supply and 1/4 return.
Re: 68 GTX 440 fuel system? [Re: NITROUSN] #2786401
06/17/20 01:37 PM
06/17/20 01:37 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
iagree & vapor separator behind alternator
Re: 68 GTX 440 fuel system? [Re: jlatessa] #2786402
06/17/20 01:37 PM
06/17/20 01:37 PM
Kirkland, Washington
Pacnorthcuda Offline
I believe this is correct.
Re: 68 GTX 440 fuel system? [Re: Pacnorthcuda] #2786443
06/17/20 03:00 PM
06/17/20 03:00 PM
N
N
The GTX or most all 68-70 B- Body 440 cars ran a two line system. 3/8 Supply and 1/4 inch return. 5/16 single line was on the 383 and smaller engines.
Re: 68 GTX 440 fuel system? [Re: NITROUSN] #2786794
06/18/20 01:10 PM
06/18/20 01:10 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
FWIW, the '68 parts manual shows only 5/16" for the fuel supply.
Re: 68 GTX 440 fuel system? [Re: John_Kunkel] #2786802
06/18/20 01:29 PM
06/18/20 01:29 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
Ive never owned a 1968.
But. Have owned 4 of a 1969 GTXs. All 440 cars . And none have had the 3/8" main line.
All 4 have been 5/16 with the 1/4" return line.
3 of them St Louis built....1 was Lynch road i think
Re: 68 GTX 440 fuel system? [Re: Chally426] #2786832
06/18/20 02:19 PM
06/18/20 02:19 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
What was the factory transmission for this car? 4 speed for automatic? It makes all the difference.
Re: 68 GTX 440 fuel system? [Re: gtx6970] #2786945
06/18/20 08:18 PM
06/18/20 08:18 PM
N
N
I might be wrong but I do not think I have ever seen a 68-70 tank sender with 5/16 and a 1/4 return. As far as I know they were only 3/8 and 1/4.
Re: 68 GTX 440 fuel system? [Re: NITROUSN] #2786963
06/18/20 09:36 PM
06/18/20 09:36 PM
It's a dry heat
It's a dry heat
thats the odd part. every one had the correct 3/8" sender with the 1/4" return , yet ALL 4 cars had the 5/16" main line with the 1/4" return line beside it
Re: 68 GTX 440 fuel system? [Re: Chally426] #2787623
06/21/20 01:33 AM
06/21/20 01:33 AM
California
BigDaddy440 Offline
BigDaddy440  Offline
California
I can tell you that my 68 Dodge R/T with a 440 and auto-trans had 3/8" fuel line from the factory. Interestingly, A12 (440 Six Pack / BBL) Roadrunners and Super Bees had 5/16" fuel lines, at least that's my experience.
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: 68 GTX 440 fuel system? [Re: BigDaddy440] #2787626
06/21/20 01:46 AM
06/21/20 01:46 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
that is correct, because A12 cars are 383 cars with a drivetrain upgrade & the fuel system was NOT modified/changed
Re: 68 GTX 440 fuel system? [Re: 6bblgt] #2788387
06/23/20 09:53 AM
06/23/20 09:53 AM
Columbus, Ohio
Columbus, Ohio
Well... Found a pic during the tear down.. but cant post it for some reason.....Looks like 2 lines for sure.. So would you say 3/8" and 1/4" return line with a fuel separator?
Re: 68 GTX 440 fuel system? [Re: Chally426] #2788991
06/24/20 09:15 PM
06/24/20 09:15 PM
California
BigDaddy440 Offline
BigDaddy440  Offline
California
That sounds right to me.
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
