Engine building tools
#2785756
06/15/20 03:23 PM
06/15/20 03:23 PM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
I typically pick up a new tool with each customer motor I build. It may be a simple as a ring compressor or more significant like the Total Seal electric ring filer.
Here are a few pictures of my main engine building tools, not shown are light valve checking springs, PAC install height gage/mic, Andy's BB and SB metal plates for mounting dial indicator for checking lifter, valve or rocker height/travel, adjustable length checking push rod, dial caliper, engine brushes, solvent tank, 9" bore flashlight, mirrors.
What other tools have you engine builders found useful that I don't have and should consider?
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
Re: Engine building tools
[Re: 383man]
#2785857
06/15/20 08:59 PM
06/15/20 08:59 PM
Posts: 16,932 NC
440Jim
NC
I am a camshaft measuring crazy man. So for roller cams, I like a lifter tool with a ball on the end (wheel dia). The o-ring seal on the lifter bore is nice to hold it in place. From the Comp Cams web site: Comp Cams web page linkI actually made my own with a dia for Mopar. Since you have a KB block with the double side bolts, I made a tool to press the caps on straight. It also removes them easily, but that is nothing special.
[Re: Cab_Burge]
#2785939
06/16/20 09:47 AM
06/16/20 09:47 AM
Posts: 2,687 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I bought my Sunnen dial bore gage (.0001") in 1977 for I believe $700. (About the same price as a Hemi convertible.) It seemed like a lot of money but it's the best. It's easy to use and you will really know your clearances. Today they are only $1,000. A few decades later I saved up enough to buy the Sunnen setting fixture. ($2,000.) You will start wanting one of those the day you get your dial bore gage. Don't be afraid to spend a lot of money on the best tools. They last a lifetime. 1977 was over 40 years ago.
2011 Drag Pak Challenger
[Re: rickseeman]
#2786198
06/17/20 12:11 AM
06/17/20 12:11 AM
Posts: 3,505 DFW
mr_340
DFW
I bought my Sunnen dial bore gage (.0001") in 1977 for I believe $700. (About the same price as a Hemi convertible.) It seemed like a lot of money but it's the best. It's easy to use and you will really know your clearances. Today they are only $1,000. A few decades later I saved up enough to buy the Sunnen setting fixture. ($2,000.) You will start wanting one of those the day you get your dial bore gage. Don't be afraid to spend a lot of money on the best tools. They last a lifetime. 1977 was over 40 years ago. I've bought a few Mitutoyu ring gauges to set my dial bore gauges. Is this the unit you have? https://goodson.com/products/sunnen-dial-bore-gauge-setting-fixtures
Floyd Lippencott IV
[Re: mr_340]
#2786208
06/17/20 02:53 AM
06/17/20 02:53 AM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
I bought my Sunnen dial bore gage (.0001") in 1977 for I believe $700. (About the same price as a Hemi convertible.) It seemed like a lot of money but it's the best. It's easy to use and you will really know your clearances. Today they are only $1,000. A few decades later I saved up enough to buy the Sunnen setting fixture. ($2,000.) You will start wanting one of those the day you get your dial bore gage. Don't be afraid to spend a lot of money on the best tools. They last a lifetime. 1977 was over 40 years ago. I've bought a few Mitutoyu ring gauges to set my dial bore gauges. Is this the unit you have? https://goodson.com/products/sunnen-dial-bore-gauge-setting-fixtures I believe the one he is talking about is the 2-6” dial bore gauge. The other one is not large enough for common rod and main bearing measurements. It is an awesome piece of equipment and will last for many decades with increadible repeatability.
[Re: rickseeman]
#2786269
06/17/20 09:26 AM
06/17/20 09:26 AM
WadeMetzinger
Tulsa, Ok
I'd need to take a class on how to use that... I think I know how to use the dial bore gauge but what is the fixture used for and why?
[Re: WadeMetzinger]
#2786278
06/17/20 09:46 AM
06/17/20 09:46 AM
Posts: 5,167 CT
GTX MATT
CT
If you want a valve spring checking tool, and you already have a hydraulic press, a regular analog bathroom scale and a dial indicator will allow you to measure them. You need an analog scale that goes up pretty high though unless you're using stock type springs, a standard $15 300 lb scale is not very accurate at 300 lbs, but will work if you just want to make sure seat pressures are where they should be for most applications.
I really like the big blue moroso wheel for degreeing cams, too big to use in most cars but really easy to read. If you're like me though you will start writing down 0.25 and 0.5 degree increments.
Also engine bags are really pretty cheap, but I hardly ever see anyone I know using one when they build an engine at home. They are well worth it.
One day I'll have a nice dial bore gauge!
[Re: WadeMetzinger]
#2786394
06/17/20 01:28 PM
06/17/20 01:28 PM
Posts: 43,317 Bend,OR USA
Cab_Burge
Use your mike for setting up the dial bore gauge zero, make sure and use the checking standard for your mike to ensure that zero is zero on the mike ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif) I have a Sunnen dial bore gauge that rears in .0005 increments, not the better .0001. , I also got the checking fixture for it but I don't use it do to the possibility of errors by stacking the checking standards and dirt or dust getting in between those parts, I don't use it now. I also have a Mit (SP) dial bore gauge that does read in .0001 increments so I use it instead of the Sunnen ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
[Re: WadeMetzinger]
#2786428
06/17/20 02:35 PM
06/17/20 02:35 PM
rickseeman
Stuttgart, Arkansas
I've been considering upgrading my Snap-on torque wrench to one of their new electronic one that don't just click once you've reached your torque setting but also tell you digitally exactly how much your torqued. At time when your torquing nuts you can feel it slide just as it reaches the specified torque and sometimes when it clicks it sort of sneaks up on you and you don't stop immediately but you really don't know if you over torqued or not.
I've got a cheaper brand 1/4 inch pound torque wrench I could up grade but I don't use it much and I wouldn't mind getting a torque wrench that goes beyond 150lbs that my Snap-on maxes out at. I have a couple of those. They have their place. If you buy one (and they b pricy) get the one that does degrees also since some fasteners want it done that way now. And take the batteries out when you get done with it or they will be dead the next time you want to use it.
