Overcharge? #2782103
06/06/20 12:54 PM
06/06/20 12:54 PM
Fox River Grove, IL
HotRodRailroader Offline OP
Fox River Grove, IL
1969 RR took it out the other day and as it was warming up the amp meter spiked and wouldnt come down. I figured a voltage regulator because it has happened before. Replaced it with a really good quality standard part. Made in USA. Replaced it and same thing is happening. Un hooked the battery and the car actually revs up to 4 grand and the gauges start to spike. So I hooked up the battery and parked the car again. Once it was off I unhooked the battery. Is it a junk alternator? Or am I going to be chacing grounds for a short?
Re: Overcharge? [Re: HotRodRailroader] #2782107
06/06/20 01:04 PM
06/06/20 01:04 PM
Andrewh Offline
Andrewh  Offline
you probably need to confirm a few things first.
check the voltage at the sensing wire for the voltage reg, the car can be in run, but doesn't have to be running.
see how close it is to the battery voltage.
use the battery for ground on battery, but use the case of the voltage reg for ground when you check voltage there.
if there is a difference then use the battery as ground and see if it goes away.
if not then I would be looking at the bulkhead connector and tracing it back to the ignition to see where you lose the voltage.
if the difference went away when you changed to battery ground, then the vr isn't grounded properly.
If it matched battery voltage, and you know this vr is good, then I would be getting the alt tested.
Re: Overcharge? [Re: Andrewh] #2782112
06/06/20 01:12 PM
06/06/20 01:12 PM
Fox River Grove, IL
Fox River Grove, IL
Thanks I'll go check it out!
Re: Overcharge? [Re: HotRodRailroader] #2782131
06/06/20 01:55 PM
06/06/20 01:55 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Have you tried swapping batteries. Yours may have an internal short. Besides it's an easy check.
Re: Overcharge? [Re: HotRodRailroader] #2782206
06/06/20 06:00 PM
06/06/20 06:00 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Once I got an intermitent short on my alt able to get between 18 up to 24 volts depending on RPMs... but without load, so I disconected the batt and engine died. It was one of the rotor vent vanes getting in touch with one of the stator leads on every spin.
BUT... the engine never increased the RPMs by itself. Just sharing one misterious experience I had
Re: Overcharge? [Re: NachoRT74] #2782266
06/06/20 09:20 PM
06/06/20 09:20 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
when I've had overcharge issues it's always been the voltage regulator had a poor ground. anymore I run a pigtail off the regulator and ground it to the block.
Re: Overcharge? [Re: HotRodRailroader] #2782307
06/07/20 04:00 AM
06/07/20 04:00 AM
Motor City
JTECDN Offline
JTECDN  Offline
Motor City
Another easy check is unplugging the field wire at the alternator. If you are still max charging then you have an internal alternator short from the field to ground. This happened to me recently - I havent take the alternator apart yet but the pulley side bearing is so worn you can move the shaft around. good luck
Re: Overcharge? [Re: HotRodRailroader] #2782539
06/07/20 09:14 PM
06/07/20 09:14 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
The only thing I would add to AndrewH's suggestions is to note whether the Ammeter 'charging' followed the rpms from slow idle to 1500 rpm.
When you post back, if the problem is not resolved, tell us if this is an unaltered factory system.
Re: Overcharge? [Re: lewtot184] #2782832
06/08/20 02:44 PM
06/08/20 02:44 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
On the electronic reg with dual fields the car wont charge if the reg is not grounded since that's the field ground. Course you may be talking of the older mech regulator only ? Working many years at a Dodge dealer I found the two wire connector on the electronic reg would loose its connection at the reg for the batt sense wire but the field wire still had a good connection and of course it would overcharge without knowing batt volts. Unhook the field wire or wires depending on your reg and see if it stops charging like was said. Ron
Re: Overcharge? [Re: HotRodRailroader] #2784593
06/12/20 12:35 PM
06/12/20 12:35 PM
Fox River Grove, IL
Fox River Grove, IL
Went out to do more checking and everything seems to check good. I didnt not unhook the regulator to see if it stops yet. However it keeps saying overcharge with the rpm increase. I put my volt meter on the battery top posts. As I rev the engine it goes up to 14.4 or 14.5 and stops there when its revving up. Yet the amp meter inside pegs all the way to the right to the point where it bounces. Possible worong in dash issue or does it still sound like an alt or battery issue?
Re: Overcharge? [Re: HotRodRailroader] #2784595
06/12/20 12:47 PM
06/12/20 12:47 PM
Andrewh Offline
Andrewh  Offline
that is odd and doesn't really explain the reving when the battery is unhooked.
can you see the meter and gauge at the same time?
Re: Overcharge? [Re: Andrewh] #2784724
06/12/20 07:10 PM
06/12/20 07:10 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
I agree^^^^^
Is this 100% factory wiring?
No electic fans, fuel pumps, winches.. ?
If so, my first suspicion would be the battery. if its in low state of charge, or has a plate detach, it would suck current like crazy.
Second suspicion would be some sort of short. Maybe cross wire or maybe with chassis. The fact the instrument gages are sometimes effected really has me concerned about that.
There were some options that drew power from the battery side of the ammeter. I think some years/models a clock option was tied in there.
Re: Overcharge? [Re: Mattax] #2784817
06/13/20 12:31 AM
06/13/20 12:31 AM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
If the battery has a shorted plate it will still show 14.5 Volts but be taking all the Amps the alt can push thru the Amp gauge.
Use all safety gear around battery acid.
I'd check to see if you have 2.5+ volts in each port of the battery.
1.Unscrew all filler caps on the battery.
2. Put the BLACK Neg cable of your VOM on the battery's Neg lug. Put the RED Pos cable of the VOM into the acid of the first hole. Should be 2.5 to 2.7 Volts DC. Yes, into the acid. You do not need to touch the lead plate inside.
3. Move the cables of the VOM up a hole and measure.... Rinse and repeat. Should be balanced at all holes.
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
Re: Overcharge? [Re: Dave_J] #2784819
06/13/20 12:39 AM
06/13/20 12:39 AM
Kirkland, Washington
Pacnorthcuda Offline
I’ve been working with automotive batteries for 50 years. You haven’t a clue about what you are talking about.
Re: Overcharge? [Re: Pacnorthcuda] #2784851
06/13/20 08:20 AM
06/13/20 08:20 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
50 years wasted
http://constructionmanuals.tpub.com/14273/css/Battery-Voltage-Test-40.htm
Re: Overcharge? [Re: Dave_J] #2784855
06/13/20 09:23 AM
06/13/20 09:23 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I have seen this a few times in my 40 plus years as a tech. Battery cell problem where the volts wont go over a certain amount usually from about 13 to 14.5 but put an ammeter in series in the alt output wire and the alt is putting out all it can. I have seen well over 50 amps on cars with alt's that high of amperage and yet the battery volts wont come up enough for reg to cut alt amps back. You have to hook an ammeter up along with a voltmeter to properly diagnose that problem. Put a new battery in and problem solved. But I never checked each cell that way though. Usually a good battery reads about 12.6 or 2.1 volts per cell. Ron
Re: Overcharge? [Re: Sniper] #2784908
06/13/20 11:24 AM
06/13/20 11:24 AM
50 years wasted
So you agree with his post? 2.5-2.7 volts per cell and you don’t touch the plates? Really?
Re: Overcharge? [Re: Pacnorthcuda] #2784976
06/13/20 02:34 PM
06/13/20 02:34 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
50 years wasted
I'm soooo sorry I got it 0.4 volts wrong. You are soooo right. You win the prize for the day. eyes
But just try doing the test and see if you get between 2.0 to 2.2 volts in each cell.
Not sure who PI$$ED in your Cornflakes this morning.
65 Formula S Cuda
Re: Overcharge? [Re: Dave_J] #2786041
06/16/20 02:29 PM
06/16/20 02:29 PM
Fox River Grove, IL
Fox River Grove, IL
So took the battery in and it tested good. Guess it time to pull the alternator and have that tested
Re: Overcharge? [Re: HotRodRailroader] #2786150
06/16/20 09:19 PM
06/16/20 09:19 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
The batter yis fully charged?
What were the results of checking for voltage differences? (see post 2)
No need to disconnect the regulator.
Just measure the voltage the regulator is 'seeing'. That's the 'ign' terminal.
After that, check the voltage at the alternator output stud.
Compare with voltage at the battery positive.
Best done while running.
