426 hemi water in head bolt holes #2786024
06/16/20 01:48 PM
06/16/20 01:48 PM
Dallas,tx
glorydays123 Offline OP
Dallas,tx
Been chasing some milky oil... Pulled the driver side head. I pour water in the holes between 5-7 and both head bolt holes fills up with water... not normal correct? perhaps i found where the oil and water is getting in when the head is on water pushing up into the head... just a thought. be easy on me i'm a newbie... smile best way to fix or what would you do? picture coming soon
Junior
Re: 426 hemi water in head bolt holes [Re: glorydays123] #2786045
06/16/20 02:53 PM
06/16/20 02:53 PM
Dallas,tx
Dallas,tx
When in doubt. look up the FSM hahahha it calls for Sealer.. I'm just going to button it up and then run a radiator pressure test to see if i hear air... in the block for a crack...
Re: 426 hemi water in head bolt holes [Re: glorydays123] #2786053
06/16/20 03:19 PM
06/16/20 03:19 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Usual cause is the deck or head is little warped and the intake bolts are over tightened - it will lift the head up off the head gasket just enough - intake bolts are only 48 inch/lbs for the two outer and 78 inch/lbs on the four inner using a sequence to tighten. Use some sealer on your head gaskets around the water holes - just a light smear is all you need
Re: 426 hemi water in head bolt holes [Re: glorydays123] #2786079
06/16/20 04:55 PM
06/16/20 04:55 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
A manufacturer of after market blocks I had drilled the head deck holes right into the water jacket...They have to be checked before assembly...
Re: 426 hemi water in head bolt holes [Re: glorydays123] #2786128
06/16/20 07:59 PM
06/16/20 07:59 PM
Alumnaseal is your friend on sealing leaks like those up scope
Re: 426 hemi water in head bolt holes [Re: Cab_Burge] #2786154
06/16/20 09:26 PM
06/16/20 09:26 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Indian head shellac on the block side stud, or bolt threads, and it won't leak.
