Re: TH400 to RB in 69 b body info
[Re: Clanton]
#2802327
07/28/20 10:44 PM
07/28/20 10:44 PM
Posts: 2,463 Sydney,Australia
tex013
Sydney,Australia
i have always found the lokar a pain to fill and sometimes check . But you are looking good
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: moparx]
#2802517
07/29/20 01:18 PM
07/29/20 01:18 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
i too, am wondering about how long it will take you to fill the transmission with that dipstick setup. and also, sorry for your loss. I put 3qts in under 2 minutes from a gal jug of Max Shift 1 in the vert. adding some progress pic
[Re: Clanton]
#2802650
07/29/20 08:23 PM
07/29/20 08:23 PM
Clanton
northern,Ohio,USA
My converter bolts are short that I got with it at 1.250" long so lucky I got some at summit that are 1.5" but the bolt is about 1 thread away from hitting the front cover of the vert so I think I can use it.I did not tq it to 60ft lbs but if it hits then I think I can grind a tapper on the bolt so it will clear.Look at the vert bolt pad and the front of the vert and maybe you can see what I mean.
[Re: moparx]
#2802891
07/30/20 01:27 PM
07/30/20 01:27 PM
Clanton
northern,Ohio,USA
could you use a 12pt head like on an ARP bolt to help with clearance ? That would not help me the bolt is just on the edge of too long.I can grind off .050" from the length.The bolt I got with the vert had no threads past the nut What I ended up doing is taking a feeler gauge and checking the gap after I ground .035 off all the bolt threads and ended up with .080" befor tqing the bolt[about 2 threads gap]
[Re: moparx]
#2803376
07/31/20 05:53 PM
07/31/20 05:53 PM
Clanton
northern,Ohio,USA
after re-looking at the picture, would it be possible to use a jam nut for a rod end ? that would allow a bit more clearance. [i think ?] I cut/sanded off 3/4 of 1 thread[.035"] of the bolt to keep the bolt from bottoming out on the converter cover and after torquing I had about .050 to .060" gap.The nut on the bolt is fine.I used red loctite. at 55lbs.grade 8 bolt.
[Re: dvw]
#2803752
08/01/20 02:42 PM
08/01/20 02:42 PM
Clanton
northern,Ohio,USA
What did you ever do about the cross member you cut out? Never saw a picture of it being reinforced. The floor sheet metal alone isn't going to cut it. I'd fix it now before you possibly damage a very expensive purchase. Doug I have not done anything with the trans member or floor yet.How/what should I do to it?to start I was going to fill in the open area with 1 piece .125" thick and as wide as the frame bolt holes
[Re: Clanton]
#2803794
08/01/20 04:23 PM
08/01/20 04:23 PM
Clanton
northern,Ohio,USA
I put the starter in and then started lashing the valves and I can hear the starter ring spin the starter gear so I will have to shim the starter with the shims that came with the ultra bell.The kits came with a starter nose extension but how do I know when to use that? ps:The starter took 2 shims to get off the ring gear about .040".No more noise when I lashed the valves.
[Re: Clanton]
#2804097
08/02/20 10:12 AM
08/02/20 10:12 AM
Clanton
northern,Ohio,USA
What did you ever do about the cross member you cut out? Never saw a picture of it being reinforced. The floor sheet metal alone isn't going to cut it. I'd fix it now before you possibly damage a very expensive purchase. Doug I have not done anything with the trans member or floor yet.How/what should I do to it?to start I was going to fill in the open area with 1 piece .125" thick and as wide as the frame bolt holes The big box hanging off the back can be cut off for a smaller[1"x4"] shelf the the trans mount will bolt to.I am not against making a whole new trans mount but I am using what I have to progress on other things.Your input is welcome.
[Re: nss guy]
#2805091
08/04/20 04:09 PM
08/04/20 04:09 PM
Clanton
northern,Ohio,USA
WTH happened to the balancer? LOLthe alt bolt sleeve rubbed it.The ballancer is 20 yrs old
[Re: Clanton]
#2811043
08/20/20 11:49 AM
08/20/20 11:49 AM
Clanton
northern,Ohio,USA
I opened up the trans bushing mount hole 1/4" to move it back so I can get a nut on it[10mm 1.500 nut] I found a welding shop to weld everything together and I will get a price later today at Certified welding on 9603 Clinton rd Cleveland 216-961-5410 and he welded my quick release steering wheel adapter about 6yrs ago. ps:I understand this looks like poop but we will clean things up for the finish product.
