Lower control arm bushing question #2785675
06/15/20 12:22 PM
06/15/20 12:22 PM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
I've done many, many of these in the past. With every one that I've done, I press the bushing into the control arm first, then press the shaft into the bushing. Question? How important is it that the shaft be tight in the bushing? Every one that I have done, the shaft was pressed into the bushing, and was tight. This past weekend, I replaced the bushings for a friend. One shaft was tight the other was not. I could actually pull it out of the bushing by had, very easily! (NOT sloppy loose, just snugly loose) I'm thinking the bushing is defective? With that, will anything be affected having the shaft loose?
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: Lower control arm bushing question [Re: 68LAR] #2785691
06/15/20 12:49 PM
06/15/20 12:49 PM
moparx Offline
moparx  Offline
the two things that come to my mind is, the bushing is defective or the shaft is excessively worn.
beer
Re: Lower control arm bushing question [Re: moparx] #2785695
06/15/20 12:56 PM
06/15/20 12:56 PM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
I had to press the shaft out of the old bushing,so I'm leaning toward the new bushing being defective. So, the question still is, how important is it that the shaft be tight?
Re: Lower control arm bushing question [Re: moparx] #2785696
06/15/20 12:56 PM
06/15/20 12:56 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
When the LCA moves up and down throughout the suspensions travel, the LCA bushing is supposed to deflect. If the pin is loose in the bushing, my guess is the inner metal sleeve is going to spin on the pin. That is going to wear the pin...probably very quickly.
Re: Lower control arm bushing question [Re: burdar] #2785723
06/15/20 01:45 PM
06/15/20 01:45 PM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
This is exactly what I was thinking. I have already told my friend to order another bushing.
Re: Lower control arm bushing question [Re: 68LAR] #2785778
06/15/20 05:09 PM
06/15/20 05:09 PM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
What brand bushing?
Master, again and still
Re: Lower control arm bushing question [Re: DaveRS23] #2785782
06/15/20 05:17 PM
06/15/20 05:17 PM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
Don't know what brand. He bought the parts. They came in a Rock Auto box!!!
Re: Lower control arm bushing question [Re: 68LAR] #2785786
06/15/20 05:27 PM
06/15/20 05:27 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Moog quality control sucks these days and that is the exact problem with the bad Moog parts.
Re: Lower control arm bushing question [Re: 68LAR] #2785787
06/15/20 05:28 PM
06/15/20 05:28 PM
Ontario, Canada
RealWing Offline
RealWing  Offline
Ontario, Canada
Join the crowd!!! Seems it is a significant issue with very poor off shore manufacturing quality control. Here is my recent experience. I have several more bushings on order to see if they fit.
https://www.forabodiesonly.com/mopar/threads/lca-pin-loose-in-bushing.465142/
1970 Superbird 440-6bbl, auto
1969 Barracuda 340-4bbl, FB Formula S auto
1969 Barracuda 6.1 L Hemi, 5 speed, Convertible
2022 Can Am Spyder RTL
Re: Lower control arm bushing question [Re: RealWing] #2785797
06/15/20 05:51 PM
06/15/20 05:51 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Does anyone know what brands are good or are they all made by the same factory and and put into branded packaging?
Re: Lower control arm bushing question [Re: GomangoCuda] #2785813
06/15/20 06:43 PM
06/15/20 06:43 PM
Ontario, Canada
RealWing Offline
RealWing  Offline
Ontario, Canada
They are not all made at the same factory. The 2 Moog bushings I have are made in India and both are junk.. the 2 AC Delco bushings are made in Mexico and one is good, the other is junk. I have 2 more free replacements coming, so I’ll soon know if they are ok or not. I have 2 Powerforged ones coming later this month. Some have said they are ok, but we will see. Spicer Professional Series is another make and I ordered a couple of those as well!!
The answer to that question About which ones are best is not yet known, from my perspective.
Re: Lower control arm bushing question [Re: 68LAR] #2785868
06/15/20 10:08 PM
06/15/20 10:08 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Quote
That is wrong. Shaft pressed onto bushing. Then both are pressed into the arm via the bushing outer shell (collar part)
Re: Lower control arm bushing question [Re: PhillyRag] #2785944
06/16/20 09:56 AM
06/16/20 09:56 AM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
[/color].
Quote
Doing this install the way I described, has always worked for me. Doing it the way you suggest, I really don't see any reason to make the job harder? The end result will be the same.
Re: Lower control arm bushing question [Re: PhillyRag] #2785974
06/16/20 11:09 AM
06/16/20 11:09 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Quote
It doesn't matter which order you do them, BUT if you press the bushing into the arm first you must support the inner sleeve from inside the torsion bar socket while pressing the pin in.
Check out my video:
https://www.youtube.com/watch?v=f2Op00pO6Kw
Re: Lower control arm bushing question [Re: 68LAR] #2786032
06/16/20 02:07 PM
06/16/20 02:07 PM
Benton, IL.
Special needs idiot
Special needs idiot
Benton, IL.
I have always pushed the bushing into the arm first. Only because I found it easier to support the inner sleeve with a properly sized 1/2" drive socket while pushing the shaft into it than it was to reach around the shaft to push on the outer shell.
But which ever way the installer finds easiest will work. As long as the inner shell is properly supported during the push.
And we had always used Moog suspension parts. Until the last few years. Now they are CRAP! What a shame.
Re: Lower control arm bushing question [Re: RealWing] #2786959
06/18/20 09:12 PM
06/18/20 09:12 PM
Ontario, Canada
RealWing Offline
RealWing  Offline
Ontario, Canada
Got another AC Delco bushing today (to replace the bad one) - it was also junk. 0.814" ID vs the Delco spec of 0.810.
Re: Lower control arm bushing question [Re: DaveRS23] #2786988
06/18/20 11:53 PM
06/18/20 11:53 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Well then either way is OK, but that inner shell needs support.
Re: Lower control arm bushing question [Re: RealWing] #2787012
06/19/20 08:17 AM
06/19/20 08:17 AM
Hinckley, Ohio
KWF340 Offline
KWF340  Offline
Hinckley, Ohio
Is the shaft in spec? I had a case where a new bushing rotated on the shaft. I then tried the same bushing on a different shaft and it fit tightly. So in my case the shaft was out of spec and/or the respective parts were at the opposite limits in their tolerance window.
1968 Charger R/T, 440 Auto, GG1;
1969 Super Bee, 383, 4-speed, T5;
1969.5 Road Runner, 440-6, 4-speed, 96;
1970 Duster 340, 4-speed, EV2;
1970 Charger R/T SE, 440 (496), Auto, EB3;
1970 Dart Swinger 340 (416), 4-speed, EV2;
1970 Corvette coupe, LS5, 4-speed, Daytona yellow;
2000 Corvette coupe, LS1, 6-speed, Twin Turbo, Torch red.
Re: Lower control arm bushing question [Re: KWF340] #2787045
06/19/20 10:26 AM
06/19/20 10:26 AM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
When I removed the OE shaft, it was tight on the bushing, so, just an educated guess, that the shaft is within specs. The other side went together without any problems. Everything is pointing to the bushing being defective.
Re: Lower control arm bushing question [Re: 68LAR] #2787055
06/19/20 10:54 AM
06/19/20 10:54 AM
Ontario, Canada
RealWing Offline
RealWing  Offline
Ontario, Canada
My shafts are 0.810" and 0.811" and both were pressed solidly into the old bushings, which were Moog K791 purchased back in 1999
