plug fouling #2785232
06/14/20 07:03 AM
06/14/20 07:03 AM
nj pine beach
dart9ss Offline OP
dart9ss  Offline OP
nj pine beach
I run NGK R5671A-9 & 8s in my Indy headed race engine. 14 -1 compression. What happens is After a race day when I restart the engine next time out at least the 4 corner plugs are fouled. this has been a constant thing. I think this is all from start up . I run an old 1050 8896 dominator . The car runs and idles great. It will restart after warm up with just cranking the motor no fuel required. Any thoughts, ???
Re: plug fouling [Re: dart9ss] #2785236
06/14/20 07:31 AM
06/14/20 07:31 AM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
Rich idle wet plenum floor. Fuel is trickling out to the 4 corners.
Shut off the fuel pump and let it run till it starts to die and see if it stops fouling plugs
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: plug fouling [Re: dart9ss] #2785237
06/14/20 07:32 AM
06/14/20 07:32 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Sounds like a distribution thing in the manifold.. you could put in 8 EGTs and find out I ran 8 of the EGTs
in a few of my engines
wave
Re: plug fouling [Re: dart9ss] #2785308
06/14/20 11:05 AM
06/14/20 11:05 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I’d start out by putting a kit in the carb.
Re: plug fouling [Re: fast68plymouth] #2785387
06/14/20 01:55 PM
06/14/20 01:55 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
single plane intakes can have a distribution issue with the outer cylinders burning different than the inners.
Re: plug fouling [Re: lewtot184] #2785506
06/14/20 08:15 PM
06/14/20 08:15 PM
nj pine beach
dart9ss Offline OP
dart9ss  Offline OP
nj pine beach
thanks all , I'm eyeing up a gen 3 to replace the old 1050'
Re: plug fouling [Re: dart9ss] #2785548
06/14/20 10:21 PM
06/14/20 10:21 PM
I've tried and ran a bunch of the early non HP 1050 dominator on a single four single plane intake for bracket racing, the #9375 is the best one I've found for best performance out of the box with stock jetting, the one you have now was not so great down
Contact Dominic, ThumperDart on here, for a custom built state of the art race carb for your motor twocents up scope
Re: plug fouling [Re: dart9ss] #2785665
06/15/20 12:00 PM
06/15/20 12:00 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I can put you in a top shelf billet bad dog for a few bucks more than the cast stuff and all I build are 2-circuits w/ one of my customers going a 1.06 60 ft. and 4.70's in the 1/8.....one of many I've done....
Re: plug fouling [Re: Thumperdart] #2785681
06/15/20 12:27 PM
06/15/20 12:27 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I will put this out there, as it was my experience with NGK plugs a while back......I have used them from daily driver to bracket racing and even N2O racing......My experience was when they saw too much fuel, they just plain quit. Like the added resistance to light the fuel some how made the box put out a little more juice to light them, and it burned out somthing in the plug...Mine would not come back. And like you, it was generally the same plug positions over and over. I really hated those things when I figured it out. I have tried a lot of plugs since then.....
My favorite now is the Autolite Racing Plugs AR3935 (I think thats the number) I love those things. Season after season, no issues. Fire the car in the dead of winter, fuel puddling all over the place...still lights....Now those are like an NGK7 I think, but they make an AR3934 which is an NGK8 equivalent if I remember right.
I used to buy three sets a year.....Now, I buy one set, and it lasts me two years.
I would [censored] can the plugs and try a set of these.
Re: plug fouling [Re: Dragula] #2785689
06/15/20 12:46 PM
06/15/20 12:46 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
And I had negative issues w/Autolite but a super rich mixture will kill any plug cos it's all in the tune and my plugs live and look great after months of street driving which is WAY more critical than race only....
Re: plug fouling [Re: Dragula] #2785818
06/15/20 07:05 PM
06/15/20 07:05 PM
WA
JD Dart Offline
JD Dart  Offline
WA
What I didn't like about the Autolite Racing Plugs AR3935 it would 60' better with them but mph less weird but that was the results I had.
best so far 8.53 @ 158.59 MPH 60'1.240
