Re: Coolant near BB head locating pin?
[Re: 68_661charger]
#2784867
06/13/20 10:10 AM
06/13/20 10:10 AM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
I would suggest a composite gasket. Sealer may work with the steel shim, but you’re probably getting tired of pulling the head.
[Re: TRENDZ]
#2784869
06/13/20 10:16 AM
06/13/20 10:16 AM
Posts: 949 Indiana
68_661charger
Indiana
Id do it once again if the rtv trick might work. CR is measured low so it would be great to keep the shim gasket.
[Re: 68_661charger]
#2784909
06/13/20 11:26 AM
06/13/20 11:26 AM
Posts: 14,493 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
To answer your question........ the small hole to the right of the dowel pin hole in your first pic is a coolant hole.
If the leak is as minor as you say, I can’t imagine that a dose of stop leak wouldn’t solve it.
As for the composition gasket......... mill the heads .020 and use a Fel-Pro 8519 gasket, and you won’t lose any compression...... as well as have a flatter head with a better surface finish(if done on good equipment).
[Re: 68_661charger]
#2785721
06/15/20 01:42 PM
06/15/20 01:42 PM
Posts: 43,127 Bend,OR USA
Cab_Burge
Do the dowel pins go all the way into the water jacket on the block?
Not on any early (pre 1990) Mopar V8 blocks I've seen or heard of
