Nicopp Fuel Lines... Flare or Compression fitting? #2784437
06/12/20 02:39 AM
06/12/20 02:39 AM
Chicago, Illinois
Devil Offline OP
Devil  Offline OP
Chicago, Illinois
I'm about to run all new fuel lines for my Sniper EFI on my 71 Challenger. With the fuel filter in line, I'll have 4 ends on the feed side.
I was planning on just flaring the ends, add some EFI style clamps and be done. A few friends said that will leak and I should use use a setup like this.
What do you think?
Re: Nicopp Fuel Lines... Flare or Compression fitting? [Re: Devil] #2784463
06/12/20 07:23 AM
06/12/20 07:23 AM
Torq37 Offline
Torq37  Offline
I've never had a problem doing single 37 degree flares but I do cut the tube with a hacksaw to avoid work hardening that occurs with a tubing cutter. I also use a burnishing style flaring tool.
Re: Nicopp Fuel Lines... Flare or Compression fitting? [Re: Torq37] #2784522
06/12/20 10:00 AM
06/12/20 10:00 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
flare with a pair of hose clamps will work just fine. you'll create more headaches with that setup that you show. if anything go right to an fittings from the tube and skip the rubber hose
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Nicopp Fuel Lines... Flare or Compression fitting? [Re: Jerry] #2784597
06/12/20 12:51 PM
06/12/20 12:51 PM
MarkZ Online boogie
Worthy
MarkZ  Online Boogie
Worthy
You got the Master Kit that includes the pump and filters? I did my Sniper system 3/8" Ni-Copp. Just flare the tube and use AN fittings with hose ends (not barbed) and fuel injection clamps.
Re: Nicopp Fuel Lines... Flare or Compression fitting? [Re: MarkZ] #2784602
06/12/20 01:06 PM
06/12/20 01:06 PM
Chicago, Illinois
Devil Offline OP
Devil  Offline OP
Chicago, Illinois
That's a good idea on the AN fittings.
No, I pieced mine together. I learned what filter they used (Corvette TBI Filter) and a Spectra EFI tank.
I got a reman'd Sniper setup.
https://www.ebay.com/itm/Holley-Sniper-EFI-550-511-Factory-Refurbished-Self-Tuning-Throttle-Body-Kit/283508683173?epid=230253296&hash=item42026f31a5:g:ZhgAAOSws59c-Ydt
Ryan
