Re: So It Begins, 1966 Dodge Charger Restification
[Re: SportFuryS/23383]
#2780519
06/01/20 09:16 PM
06/01/20 09:16 PM
Posts: 555 Berlin, CT
SportFuryS/23383
Confused
Confused
Berlin, CT
The brake booster is on and bolted up now, it was put on May 27th 2020.
If You Ask Me This Whole World Has Gone To Hell- Creed Fisher Proud Supporter Of LGBT (Liberty Guns Beer & Trump)
#2780520
06/01/20 09:24 PM
06/01/20 09:24 PM
SportFuryS/23383
Confused
Confused
Berlin, CT
The Accel Super Stock spark plug wires and protectors or boots, the alternator and bracket, and power steering pump are now on. All of these were put on May 30th, 2020. In order starting with the spark plug wires.....
#2780523
06/01/20 09:26 PM
06/01/20 09:26 PM
SportFuryS/23383
Confused
Confused
Berlin, CT
A few more of the boots, last ones.....
#2780524
06/01/20 09:27 PM
06/01/20 09:27 PM
SportFuryS/23383
Confused
Confused
Berlin, CT
Now for pictures of the alternator.This is not the original, it is an extra one we had. The original was hard to turn so basically it was no good......
#2780526
06/01/20 09:28 PM
06/01/20 09:28 PM
SportFuryS/23383
Confused
Confused
Berlin, CT
Now for the pictures of the power steering pump. That is the original pump that came with the car, there was nothing wrong with it and worked fine so it just got a paint job.......
#2780527
06/01/20 09:30 PM
06/01/20 09:30 PM
SportFuryS/23383
Confused
Confused
Berlin, CT
Here are a couple pictures of the engine "all together", just a few more things to do.
#2780831
06/02/20 05:53 PM
06/02/20 05:53 PM
SportFuryS/23383
Confused
Confused
Berlin, CT
Took the new AFCO aluminum radiator out of the box yesterday June 1st, 2020. Pure "gold", love it. This is all I got for updates on the car for right now, have not really done anything else to it. Stay tuned.....
#2783299
06/09/20 04:09 PM
06/09/20 04:09 PM
SportFuryS/23383
Confused
Confused
Berlin, CT
Hi All,
I have a little update on the Charger for everybody, not much of one but here it is. We ordered a carburetor spacer from Jegs and we put it on the car, along with the carburetor we had sitting around that will be used. The carburetor was gone through so it does properly work, it is a 600 cfm Edelbrock so it will work for a stock 383. We put them on June 6th 2020.
#2783302
06/09/20 04:12 PM
06/09/20 04:12 PM
SportFuryS/23383
Confused
Confused
Berlin, CT
More of the carb and spacer, one more on the way
#2783303
06/09/20 04:13 PM
06/09/20 04:13 PM
SportFuryS/23383
Confused
Confused
Berlin, CT
last picture, until next time stay tuned.....
#2784335
06/11/20 10:18 PM
06/11/20 10:18 PM
SportFuryS/23383
Confused
Confused
Berlin, CT
Hi All,
I got another little update on the Charger, well kind of a big one. June 10th 2020 we mocked up and bolted in the new AFCO aluminum radiator, put the drive fan on, a new Accel Super Stock coil in, put the horns back on, put the carburetor linkage on, and even started putting the front headlight assembly and grill in. I will start the update with mocking up the new radiator. We mocked it up where we thought was appropriate and it did not work, we closed the hood to test the fitment and it fit very nicely BUT it was JUST touching the top of the cap but that was fixed......
#2784338
06/11/20 10:22 PM
06/11/20 10:22 PM
SportFuryS/23383
Confused
Confused
Berlin, CT
A few more of the radiator mock up, last ones.....
#2784348
06/11/20 10:58 PM
06/11/20 10:58 PM
SportFuryS/23383
Confused
Confused
Berlin, CT
Next we put on the Accel Super Stock coil bracket and coil, on the left in the 3rd picture is the original coil the right is the new one that will be used......
#2784349
06/11/20 10:59 PM
06/11/20 10:59 PM
SportFuryS/23383
Confused
Confused
Berlin, CT
Next we got the brake booster hose, carb linkage, and pcv valve all set and hooked up.At this point the radiator is all together......
#2784351
06/11/20 11:00 PM
06/11/20 11:00 PM
SportFuryS/23383
Confused
Confused
Berlin, CT
A few more of the linkage, cables, and hoses. Last ones....
#2784359
06/11/20 11:06 PM
06/11/20 11:06 PM
SportFuryS/23383
Confused
Confused
Berlin, CT
The horns are on now as well.
#2784361
06/11/20 11:08 PM
06/11/20 11:08 PM
SportFuryS/23383
Confused
Confused
Berlin, CT
Here is the headlight assembly and grill on now. The low beam headlights were changed to Halogen's to see better, the high beams were not changed....yet but will be at a later time. I gotta say with the headlight assembly and grill on the car now it actually looks like a car now!
#2784364
06/11/20 11:09 PM
06/11/20 11:09 PM
SportFuryS/23383
Confused
Confused
Berlin, CT
A few of the new headlights......
#2784365
06/11/20 11:11 PM
06/11/20 11:11 PM
SportFuryS/23383
Confused
Confused
Berlin, CT
A few more, last ones......
