Edelbrock Victor Jr. Hemi heads/O rings (Milodon?)
#2784033
06/11/20 10:49 AM
06/11/20 10:49 AM
Posts: 17,864 S.E. Michigan
ZIPPY
S.E. Michigan
*not* the O ring on top that seals the tube to the valve cover.
The heads are grooved for an O ring for the plug tube.
Trouble is, Edelbrock shipped the heads (at least mine) with an O ring that is not even close to the right dimension. It's way too large of OD.
I buttoned it up the old fashioned way to fire the engine, but would really prefer to use that feature to keep oil out of the chambers during plug changes.
Anyone have a part number for something that will work? (or even might work?)
(If not, my first instinct is to try to figure out what the Milodon seal kit uses, and try that)
Thanks Rich
Rich H.
Esse Quam Videri
Re: Edelbrock Victor Jr. Hemi heads/O rings (Milodon?)
[Re: ZIPPY]
#2784053
06/11/20 11:30 AM
06/11/20 11:30 AM
Posts: 14,504 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I can’t imagine they aren’t just some sort of std sized oring.
Maybe a trip to the hardware store or auto parts store with a plug tube and one of the incorrect orings to compare with would prove fruitful.
[Re: fast68plymouth]
#2784106
06/11/20 01:02 PM
06/11/20 01:02 PM
ZIPPY
S.E. Michigan
Maybe a trip to the hardware store or auto parts store with a plug tube and one of the incorrect orings to compare with would prove fruitful. Yeah I have not dug into it at all. Just thought I would ask here before spending any effort. (lazy bum.)
Rich H.
Esse Quam Videri
[Re: Cab_Burge]
#2784107
06/11/20 01:02 PM
06/11/20 01:02 PM
ZIPPY
S.E. Michigan
What does Edlbrock say I'm afraid to ask.
Rich H.
Esse Quam Videri
[Re: e85mope]
#2784108
06/11/20 01:03 PM
06/11/20 01:03 PM
ZIPPY
S.E. Michigan
Mancinni sells them. Just tell them you need the small o-ring for the machined groove at the spark plug. Wes there knew exactly what I was wanting. You know, I was kind of figuring they were probably the same as these: https://www.manciniracing.com/mareosof81.html But would be just as happy for a parker number or what have you, if someone happened to have it handy.
Rich H.
Esse Quam Videri
[Re: e85mope]
#2784110
06/11/20 01:08 PM
06/11/20 01:08 PM
ZIPPY
S.E. Michigan
I can have you a part num. tonight. thank you, I'd be grateful for it (and to see if it is the same as their milodon service kit)
Rich H.
Esse Quam Videri
