Cuda Rallye hood callouts - hidden fasteners #2783805
06/10/20 05:45 PM
06/10/20 05:45 PM
Annapolis, MD, USA
V
Vert Offline OP
Vert  Offline OP
V
Annapolis, MD, USA
This is the underside of my 71 Barracuda rallye hood. I doubt I could get a pencil between the surface and the underhood framing. Is there a secret to removing/installing the callouts? The one fastener is easy. The other ...wow.
Re: Cuda Rallye hood callouts - hidden fasteners [Re: Vert] #2783808
06/10/20 05:50 PM
06/10/20 05:50 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Originals were installed with one time use barrel nuts
https://www.ebay.com/itm/60-pcs-6-s...rel-emblem-nuts-assortment/192662604220?
Re: Cuda Rallye hood callouts - hidden fasteners [Re: gtx6970] #2783825
06/10/20 06:40 PM
06/10/20 06:40 PM
Annapolis, MD, USA
V
Vert Offline OP
Vert  Offline OP
V
Annapolis, MD, USA
These came with barrel nuts. I having problems with access to the one nut on each side that is hidden.
Re: Cuda Rallye hood callouts - hidden fasteners [Re: Vert] #2784331
06/11/20 10:09 PM
06/11/20 10:09 PM
Annapolis, MD, USA
V
Vert Offline OP
Vert  Offline OP
V
Annapolis, MD, USA
I'm thinking I'll have to pull the hood and work on it upside down to have a chance at getting to the nut behind the framing.
Re: Cuda Rallye hood callouts - hidden fasteners [Re: Vert] #2784461
06/12/20 07:05 AM
06/12/20 07:05 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
what makes you think there is a nut on the other stud behind the brace?
Like I said it 'SHOULD' be a tube style nut like shown earlier
Installing a twist on pal nut like the one stud shown would be near impossible
Re: Cuda Rallye hood callouts - hidden fasteners [Re: gtx6970] #2784804
06/12/20 11:13 PM
06/12/20 11:13 PM
Annapolis, MD, USA
V
Vert Offline OP
Vert  Offline OP
V
Annapolis, MD, USA
Good point. I suppose I could remove the one nut I see and see if the emblem comes off.
Re: Cuda Rallye hood callouts - hidden fasteners [Re: gtx6970] #2792717
07/04/20 05:47 PM
07/04/20 05:47 PM
Annapolis, MD, USA
V
Vert Offline OP
Vert  Offline OP
V
Annapolis, MD, USA
Total brain fart here. I was hearing and saying barrel nut, but thinking what I had pictured. Ordered the ones you linked to. Hopefully...
Re: Cuda Rallye hood callouts - hidden fasteners [Re: Vert] #2794879
07/09/20 06:26 PM
07/09/20 06:26 PM
Annapolis, MD, USA
V
Vert Offline OP
Vert  Offline OP
V
Annapolis, MD, USA
Hemi Rallye hood.
