pilot bushing install #2783326
06/09/20 05:26 PM
06/09/20 05:26 PM
South-east Mn
blaze Offline OP
blaze  Offline OP
South-east Mn
I need to install a pilot bushing into the crank of a 400. Does it get driven all the way in? Or does it have to be flush to the outside end of the crank? Do I put any kind of grease on the input shaft of the trans? Thank you.
Re: pilot bushing install [Re: blaze] #2783346
06/09/20 06:18 PM
06/09/20 06:18 PM
McGregor,Iowa 52157
500ciDuster Online content
500ciDuster  Online Content
McGregor,Iowa 52157
The factory was flush so that's what I always did and I put a little white lithium grease input and am sure people will have a problem with that but I never have
Re: pilot bushing install [Re: blaze] #2783348
06/09/20 06:20 PM
06/09/20 06:20 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
I put them in flush. Add a little high temp grease inside the bushing.
Re: pilot bushing install [Re: rickraw] #2783386
06/09/20 07:59 PM
06/09/20 07:59 PM
MI
68shifter Offline
68shifter  Offline
MI
Use a pilot bearing from a mid 90’s Dakota. They’re roller bearing and just knock it in flush. Works great.
National-FC69907
68' Barracuda (4 speed) 64' Savoy (4 speed) 65' Satellite (girl tranny)
Re: pilot bushing install [Re: blaze] #2783448
06/09/20 10:31 PM
06/09/20 10:31 PM
Is your 400 crank stock and for a stick shift tranny? If so and your using a bushing and not the later model larger roller bearing your good up
If not you may run into fitment problems with the input shaft on the 4 speed bottoming out in that crankshaft whiney
Re: pilot bushing install [Re: Cab_Burge] #2783508
06/10/20 04:50 AM
06/10/20 04:50 AM
South-east Mn
blaze Offline OP
blaze  Offline OP
South-east Mn
Thanks guys
Re: pilot bushing install [Re: blaze] #2783513
06/10/20 06:02 AM
06/10/20 06:02 AM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
Pre-fit the bushing to the bushing id to the OD of the shaft prior to press fitting it in, Sucks finding out after it needs to be opened up.
Re: pilot bushing install [Re: RATTRAP] #2783522
06/10/20 06:49 AM
06/10/20 06:49 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
You have to be careful and check the hole diameter in the crank. Some cranks are finish reamed for a bushing and some are not. They make a bushing in both od sizes.
Re: pilot bushing install [Re: fbs63] #2783523
06/10/20 07:01 AM
06/10/20 07:01 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
The hole in the end of the crank has to be 1.750” deep or it will hit the end of the input shaft.
