Fluid damper issues #2783336
06/09/20 05:50 PM
06/09/20 05:50 PM
fredericksburg,va
cudaman1969 Offline OP
fredericksburg,va
Ok I need some answers to the fluid damper controversy. I’ve heard it breaks cranks and other problems, I’d like to hear first hand experiences not he said she said answers. Also if problems, the reasons? Thanks before I put this on the Hemi
Re: Fluid damper issues [Re: cudaman1969] #2783338
06/09/20 05:52 PM
06/09/20 05:52 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I have had mine on for 20yrs
Re: Fluid damper issues [Re: cudaman1969] #2783341
06/09/20 06:08 PM
06/09/20 06:08 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
I've had mine for 18 yrs. Have ran it on two cars and never an issue.
Ok
Re: Fluid damper issues [Re: cudaman1969] #2783356
06/09/20 06:31 PM
06/09/20 06:31 PM
AndyF Offline
AndyF  Offline
I ran one on various stroker motors for at least 20 years until I finally switched to ATI. Never had an issue. There are a few people on the internet who swear that they cause problems but I've never seen an issue with them. They really are designed for lower rpm engines so perhaps might be a better fit for a stroker motor than a high winding drag race car.
Re: Fluid damper issues [Re: AndyF] #2783373
06/09/20 07:25 PM
06/09/20 07:25 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
iagree
They are basically a mechanical tuning item, and each motor/application has different needs, each damper has a different optimum rpm range, some chose poorly.
ATI online has a posted graph that displays this fairly well, IMO
Re: Fluid damper issues [Re: jcc] #2783396
06/09/20 08:32 PM
06/09/20 08:32 PM
fredericksburg,va
fredericksburg,va
I was waiting for you two guys to answer. 4.15 crank on a 4 speed street engine. I have all three, ATI, BHJ and FLUID DAMPER I like the FD because it’s thick like the stock one but recessed to use the 440 pully
Re: Fluid damper issues [Re: cudaman1969] #2783400
06/09/20 08:42 PM
06/09/20 08:42 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Too much harmonics with Fluidamper.. Bearings always looked schmeary . Switched to ATI. Never an issue again.
Re: Fluid damper issues [Re: cudaman1969] #2783403
06/09/20 08:55 PM
06/09/20 08:55 PM
AndyF Offline
AndyF  Offline
If you have a FD damper on hand that fits your application then I'd use it. It should work just fine with a 4.15 stroke street engine. I wouldn't use a FD on a circle track engine or a high winding drag engine but a stroker street engine should be just fine. FD are really designed for diesel engines and truck engines and such but they seem to work okay on passenger cars too. I think it is very important to have the rotating assembly properly balanced regardless of which damper you use.
Re: Fluid damper issues [Re: AndyF] #2783421
06/09/20 09:38 PM
06/09/20 09:38 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
My 572 has had a Fluid Dampner going into its 8th year, 650 passes. Bearings have been fine. The rod bearings have well over 350 passes. At last check looked like new. And I bought it used.
Doug
Re: Fluid damper issues [Re: dvw] #2783438
06/09/20 10:17 PM
06/09/20 10:17 PM
Cab_Burge Online work
Cab_Burge  Online Work
I think early on after Fluid dampers first came out after NHRA mandated the use of them in some classes some guys broke cranks and blamed that on the dampener being revved up when the outside air temps where below freezing shruggy
Maybe they had cracks in their cranks before switching work
Re: Fluid damper issues [Re: Sammy] #2783455
06/09/20 10:54 PM
06/09/20 10:54 PM
fredericksburg,va
fredericksburg,va
The bearings that came with the crank looked blackened but no other blemishes and the crank checked out great. Was in a race engine (world block). He was going to a 4.5. crank
Re: Fluid damper issues [Re: cudaman1969] #2783491
06/10/20 01:11 AM
06/10/20 01:11 AM
Washington
madscientist Offline
Washington
I shifted as high as 8800 with a fluidamper on OE cranks and never broke a crank and the bearing looked perfect. They are not low RPM dampers.
Re: Fluid damper issues [Re: cudaman1969] #2783515
06/10/20 06:19 AM
06/10/20 06:19 AM
PA
Harry's Taxi 2 Offline
PA
I've had one since they first came out. 30yrs?......doesn't have the recess for the crank pulley. three different engines and never saw any negative bearing wear. stock stroke to 4.15 and max rpm of 7500.
ATI's own graph even shows them to be the better choice up to a certain RPM.
They are heavier than ATI's, but that might even be a plus.....although the initial rotating mass portion may be lighter than ATI's?
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
Re: Fluid damper issues [Re: Harry's Taxi 2] #2783976
06/11/20 07:47 AM
06/11/20 07:47 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I ran one on my race engine that was turning 8200 rpm and one still on my street rod
thats a 7300 rpm 416 stroker.. I have never had any issue.. both of those are using a
motor plate and I dont feel anything weird
wave
Re: Fluid damper issues [Re: cudaman1969] #2784159
06/11/20 02:54 PM
06/11/20 02:54 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
20 plus years 4 different engines
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Fluid damper issues [Re: cudaman1969] #2784174
06/11/20 03:26 PM
06/11/20 03:26 PM
New York
polyspheric Offline
polyspheric  Offline
New York
RPM isn't directly a factor.
The question is: will the engine operate at a higher RPM which includes another destructive harmonic order? If yes, the damper design is different.
Mistakes from 50 years ago: Ford 289 210 hp owners install high-perf 271 hp and Cobra parts, including the cam. The 210 hp low-perf damper does nothing above 5,000, the 271 cam works above that. Wrong damper: broken crank.
Boffin Emeritus
Re: Fluid damper issues [Re: polyspheric] #2784179
06/11/20 03:50 PM
06/11/20 03:50 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Poly.. was that the fault of the balancer or the fault of the crank or design of the engine and
would newer say 20 year old work.. I've been running them for a few years
wave
Re: Fluid damper issues [Re: MR_P_BODY] #2784211
06/11/20 04:44 PM
06/11/20 04:44 PM
New York
polyspheric Offline
polyspheric  Offline
New York
The 271 has a different damper, which suppresses harmonics in the higher RPM range.
Boffin Emeritus
Re: Fluid damper issues [Re: Sammy] #2784215
06/11/20 04:54 PM
06/11/20 04:54 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
And my vibration went away instantly when I went with ATI..........
Re: Fluid damper issues [Re: Thumperdart] #2784221
06/11/20 05:22 PM
06/11/20 05:22 PM
Washington
skrews Offline
skrews  Offline
Washington
Seems like crankshaft manufacturers don't like the fluid dampers too much.
